IS350 (brake) Upgrade on IS250
Old 06-26-17, 07:39 PM
  #91
XSV
XSV's Avatar
Originally Posted by ldc
For looks did you say?�� 1.5k just for small upgrade to looks I know what you can do to get much bigger upgrades to looks , for as little as 20 bucks.
​​​​​​Anyway it's not all about what is been done but the journey if doing it that gives people satisfaction., Right?
I bought aftermarket wheels as well. Those dinky little calipers behind big wheels don't look right, that's my opinion. Like I said in my previous post, didn't plan on spending that much, but that's what happens when you modify cars, things add up real quick.
Old 06-26-17, 08:52 PM
  #92
ldc
ldc's Avatar
What I can't understand is why didn't the rear caliper comes with caliper brackets. Even the smallest of hatchbacks have rear brackets.
Old 09-07-17, 11:23 AM
  #93
TRH
TRH's Avatar
Default upgrade
Hi guys,
I've been following this thread for a while. So in the UK, as you are aware we don't have the IS350. I have now bought the GS300 caliper, but unsure if the GS300 rotor will fit the IS250?
There is not much info on the UK forums. The IS250 rotor Diameter is 296mm and so are the GS300, Can I just use the 250 rotor? any input will help.
TIA
Old 09-10-17, 09:03 AM
  #94
XSV
XSV's Avatar
Originally Posted by TRH
Hi guys,
TIA
I would think so. The diameter of the GS300 Front rotor is 295.9 mm and the front rotor of an IS250 is 296 mm. I don't think 0.1 mm would be significant.
Old 09-10-17, 11:14 AM
  #95
2013FSport
2013FSport's Avatar
Received 1,535 Likes on 1,277 Posts
For all of single handed DIY; buy some speed bleeders as pumping the pedal into a submerged vat of fluid is not as good as speed blenders or two people pressure bleeding.
i.e. in car person presses pedal, builds pressure and secondary person crack bleeder letting fluid out and seals bleeder the moment fluid stops coming out.
An **additional tip** tap the caliper from the bottom while under pressure and it dislodges trapped air allowing it to escape. DO NOT tap in the direction of piston travel. You will be rewarded with a much firmer pedal by pressure bleeding and tapping than simply pumping into a jar as the threads of the bleed screws are NOT air tight.
Last thing: unless you track your car and really heat the calipers and fluid, stay with DOT3 fluid or plan on bleeding every 2 years as DOT4 fluid abosorbs moisture at nearly double the rate of DOT3. Both are hygroscopic and absorb moisture. 3 should be done every 3 years. I do it every 2.
Also, do your brake bleeding on low humidity days to reduce moisture being trapped in the system and DO NOT use fluid that was previously opened as it is absorbing moisture the moment you broke the seal.
Happy Braking....
jcgeorge (11-26-20)
Old 09-10-17, 08:43 PM
  #96
XSV
XSV's Avatar
Originally Posted by 2013FSport
For all of single handed DIY; buy some speed blenders as pumping the pedal into a submerged vat of fluid is not as good as speed blenders or two people pressure bleeding.
An **additional tip ** tap the caliper from the bottom while under pressure and it dislodges trapped air allowing it to escape. DO NOT tap in the direction of piston travel. You will be rewarded with a much firmer pedal by pressure bleeding and tapping than simply pumping into a jar as the threads of the bleed screws are NOT air tight.
Happy Braking....
don't you need a air compressor as well for bleeding machines?
Old 09-10-17, 09:33 PM
  #97
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
^^^^No!
Lou
Old 09-11-17, 07:40 PM
  #98
2013FSport
2013FSport's Avatar
Look up Speed Bleeders.... Seated, they act like a normal bleeder. Unseated, they have a pop off pressure and sealing threads. Thus you can pump the brakes and get satisfactory results.
Old 05-20-18, 07:25 PM
  #99
sinister2c
sinister2c's Avatar
My rear rattle can paint peeled so redid the paint with PPG base coat clear coat.
Old 05-23-18, 07:37 AM
  #100
ACKERIS250
ACKERIS250's Avatar
Hi!
The brake pads of my is250 are compatible with another toyota model
Old 05-25-18, 03:13 PM
  #101
MikeFig82
MikeFig82's Avatar
Originally Posted by ACKERIS250
Hi!
Cross reference the part number on a Toyota parts site. If anything it will show what vehicle they fit if any.
Old 05-26-18, 12:04 PM
  #102
2013FSport
2013FSport's Avatar
Originally Posted by sinister2c
Interesting valve stem placement there..... I'd assume you have one more conveniently located on the outside? And what about the front? Same, and it misses everything?
Old 05-28-18, 09:04 PM
  #103
sinister2c
sinister2c's Avatar
three piece wheels. Only way to mount TPMS reliably. I have a build thread on assembly of three piece wheels and drilling that hole for the TPMS.
Old 07-04-18, 10:34 PM
  #104
nickjd96
nickjd96's Avatar
I want to upgrade my front calipers on my is250 2015 to the 350 calipers. I Will I need new rotors correct? and is there anything else I need that I'm forgetting?
Old 07-05-18, 06:23 AM
  #105
XSV
XSV's Avatar
New front and rear rotors. New front pads, the rear pads are the same with the 250/350. Metal cutting sheers and a hammer to cut and modify the front dust shields and just a hammer to modify the rear dust shields for rotor clearance. While you're at it, new brake fluid to to flush out the air bubbles and old fluid. If you are buying used 350 calipers, make sure you take them apart first to make sure they do not have rust, I had to rebuild my calipers before using them,
Quick Reply: IS350 (brake) Upgrade on IS250
