I NEED HELP!! Brake Pressure is soft....
Old 11-04-08, 08:25 PM
MauiGS300
MauiGS300's Avatar
Default I NEED HELP!! Brake Pressure is soft....
I own a 1998 Lexus GS300 sport edition in Pearl White, Mileage is 92,524
& i am experiencing Soft brake Pressure everytime i brake. I checked my brake fluid it's between FULL & MIN & i recently got my car serviced i had new brake pads & new ROTORS! i dont get it? could it be a Brake Booster problem?? i took really good of my car, i dont drive FAST or brake hard??! im a second owner of this car but when i bought it i had a CARFAX reviewe from the dealership it was CLEAN!!!
CAN ANYONE HELP ME??? PLEASE??!?
Old 11-04-08, 08:41 PM
5t341th
5t341th's Avatar
did the service station bleed your brakes? sounds like its time for new fluids
Old 11-04-08, 08:43 PM
GSteg
GSteg's Avatar
Most of the time, the mushy brake feel is a result of air in the system. Check that out first before you get anything replaced.
Old 11-04-08, 08:47 PM
MauiGS300
MauiGS300's Avatar
They did FULL SERVICE, my bill says they Flushed out all the fluids & re-filled
This is what i had serviced on my car at 90K. My Head Gasket had a leak, I get it repaired as soon as possible, Changed Timing Belt & Tensioner. Flushed & refill ALL fluids, NEW Brake Pads & Rotors FRNT & REAR. HAD a Emission Tune-up. Had BOTH control arms replaced, Wheel Bearings repaired & Ball joints my total cost was & $7,500.00 estimated .
Old 11-04-08, 08:49 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
there may be air in your brake lines. have the shop bleed them again.
Old 11-04-08, 08:50 PM
MauiGS300
MauiGS300's Avatar
I took my car to the shop, to have the mechanic check my brakes. He said it was fine, but when i told him go & test drive it you can tell. So he said it must be air in the system, so he had this machine that took out all the air. Till today there was a slight difference but not that much pressure. Its so scary when i brake, i cant tell if its braking or not.
Old 11-05-08, 10:23 AM
GSteg
GSteg's Avatar
have them check to see if the caliper's piston(s) or sliding bolt(s) are frozen.
Old 11-05-08, 11:20 AM
MauiGS300
MauiGS300's Avatar
Thanks for all your responses...Im taking my car for a Final checkup, & ill mention to them about the caliper piston & sliding bolt. If thats not the problem i dont know what is???
Old 11-05-08, 04:11 PM
jcat_350
jcat_350's Avatar
unless you have a brake fluid leak, i'm willing to bet the reason your fluid is not at full (which it should be) is because they didn't completely press the pistons back in place, thus giving you less pedal travel before the piston fully engages.
that and the slide pins would cause this problem.
Old 11-05-08, 04:17 PM
JeffTsai
JeffTsai's Avatar
Bleed the brakes. 90% of the time if you have a soft pedal then the reason is due to air in the lines.
Old 11-05-08, 08:00 PM
ILOVEGIRLS
ILOVEGIRLS's Avatar
if they dont press the pistons back, they cannot put in new pads.
Old 11-06-08, 08:20 PM
FrankT
FrankT's Avatar
Stuck slide pins will cause this... but I would check for air in the lines first and do a complete fluid replacement.
good luck
Old 11-10-08, 09:08 PM
McKrevice
McKrevice's Avatar
I am willing to bet it's just air in the lines.....and 7500 bucks?! That's highway robbery.
Wallander
RX - 3rd Gen (2010-2015)
01-20-17 10:11 AM
bauer26
GX - 1st Gen (2004-2009)
03-09-13 10:48 AM
Luxor
Suspension and Brakes
06-22-09 02:04 PM
GS300 I6
GS - 1st Gen (1993-1997)
01-19-09 10:38 PM
Lexus082
15
10-17-07 03:39 PM
Quick Reply: I NEED HELP!! Brake Pressure is soft....
