Another Brake Noise Thread...
Old Jun 21, 2008 | 10:43 PM
willyc's Avatar
willyc
Default Another Brake Noise Thread...
I tried searching but didn't come up with anything, but I'm also not that great with keywords.
I recently replaced the rotors and pads on my SC400 with el cheapo Ebay brand and bled the system. The problem is that my rear right wheel has a rhythmic metal rubbing sound while driving. It sounds like it goes along with the rotation of the wheel.
The braking feels just fine, but the sound is scaring me a bit. I put grease between the back of the pads and vented shim, and between that vented shim and the outer shim. Is there another place I need to grease?
I've checked for a bent dust shield, sanded the pads a little, made sure to torque everything to spec, and tried driving w/o the hub centric rings I put on at the same time, but the sound persists.
Could it be my bearings? It would be very coincidental because the sound started right when I pulled out of the driveway to bed in the brakes and it didn't exist in any form before that.
I did have a mechanic take a look at it and he simply told me it was the quality of the rotors and pads. I know they're not that great but they'll have to do until I can afford an LS setup with decent rotors and pads.
Any ideas are greatly appreciated!
Old Jun 22, 2008 | 01:27 AM
TheMole's Avatar
TheMole
If it happens while driving and no braking then it could possibly be your wheel bearings. If the sounds occurs while braking then you might need a new shim kit or the pads have a metallic compound.
Does the wheel/caliper get really hot after a short drive? Maybe you have a seized caliper.
Did you put everything back exactly how it was? Wondering because the rears have the ebrake lines back there.
Old Jun 22, 2008 | 01:56 AM
willyc's Avatar
willyc
It occurs any time the wheel spins, so it might be the bearings?
I think I put everything together as it should be, I had my mechanic take the rears apart to inspect it and he said everything seemed fine. I'll recheck the e-brake lines tomorrow morning and check the heat of the caliper.
Thanks for your reply.
Old Jun 23, 2008 | 03:57 PM
willyc's Avatar
willyc
I finally had a chance to take a look and the e-brake seems fine and the caliper didn't feel noticeably different than the other side in temperature after a 2 mile drive.
I'm leaning towards the bearings at this point and that doesn't seem like a job I want to take on...
Oh, I forgot to ask if there is no noticeable play when I try to wiggle the wheel, could it still possibly be the bearings?
Old Jun 23, 2008 | 06:31 PM
96Es's Avatar
96Es
Does it sound like a clicking noise? I have a similar issue and it only happens when I am cruising at low speeds. I was told it could be the bearings...
I thought it was my brakes but my mechanic said they were fine. I also have a howling noise on the freeway on the same side as the click noise...
CarlitoIS
Dec 21, 2018 05:05 PM
Offspring
Oct 24, 2018 12:43 PM
Epic123
Suspension and Brakes
13
Oct 30, 2011 04:30 PM
vertcobra9
Apr 10, 2008 01:10 PM
denvergs4
Nov 1, 2007 08:05 PM
