captainva
close
- Join DateJan 2012
- LocationVirginia
iTrader Positive Feedback100
iTrader Feedback Score(1)
Liked:273 Times in 238 Posts
Quote:
96 Camry shocks done at 80k
92 es300 whole suspension shot at 100k
00 es300 suspension shot at 95k, struts, sway bar end links, lower ball joints , outer tie rod ends
07 gs450h shot at 100k struts, lower balll joints sway bar end links
12 rx450h suspension shot at 80k, struts, end links.
So wear items in the suspension had worn out around 100k? All cars require maintenance and luxury cars more so. Its a reality of life. Nothing lasts foreverOriginally Posted by samsonn25
Toyota/Lexus suspensions do suck.96 Camry shocks done at 80k
Quote:
is there a reason it happens more at low speeds? At higher speeds there is less stress?Originally Posted by repugnante
^ Yours is the first case I have seen this happen at high speeds. This problem typically occurs at low speeds. Dang, no one is safe with these. Glad you are OK>
