Daizens? What a difference!
Old Nov 6, 2007 | 08:41 PM
Wringo's Avatar
Wringo
Default A piece of mind!
Originally Posted by mikeloc24
wringo, what year is your car? I ask because I have an '02 and that seems like a lot of suspension work for a 5-year old car (in my case that is). I totally overhauled the suspension on my SC, but that car is 15 years old so it obviously needed it.
My car is a 2000 GS300! The Daizen sway's were for handling and the other upgrades were for a peice of mind knowing that the work was completed and upgraded! The upgrades are money well spent!
Old Nov 6, 2007 | 08:43 PM
GSteg's Avatar
GSteg
Originally Posted by Coco-bun
I'm on stock sway bars with coilovers almost all the way down. It feels like the sway aren't up to par with the coilovers now.
Ah yes the stock sways. They are pretty darn flexible. Upgrade to after market sway bars. I will guarantee you that body roll will be greatly reduced.
Old Nov 6, 2007 | 09:05 PM
Wringo's Avatar
Wringo
Default Time to upgrade?
Time to upgrade your sway bars! Keep in mind that I have upper strut bars in the front/rear also along with the sway bars underneath!
I agree!
Old Dec 10, 2007 | 07:48 PM
SUPRAboy80's Avatar
SUPRAboy80
so did you replace the bushing with Daizen parts and then get new oem tie rods and new oem bushings? or were those also Daizen?
Old Dec 12, 2007 | 03:42 PM
PushinLEX's Avatar
PushinLEX
The Daizen sways come with the poly brushes. Daizen makes the poly steering and control arm brushings. Lexus only makes the stock rubber brushings.
Daizen doesnt make inner/outter tie rods and ball joints, as far as I know. These are Lexus OEM parts.
Old Dec 12, 2007 | 05:23 PM
SUPRAboy80's Avatar
SUPRAboy80
Default TRD's with Daizen bushings
So has anyone here used the TRD sways with the Daizen bushings?
Old Dec 12, 2007 | 05:56 PM
GSteg's Avatar
GSteg
No one has because the trd and daizen sways have different diameter.
Old Dec 12, 2007 | 07:27 PM
SUPRAboy80's Avatar
SUPRAboy80
Well I guess since I am on the TRD sways then I should at least buy new factory bushings? My cars is a '98.
Old Dec 12, 2007 | 08:03 PM
GSteg's Avatar
GSteg
The TRD should come with bushings already. I dont remember the diameter (stock vs TRD) off the top of my head, but I didn't know you can use OEM bushings. Get new bushings if you must. Can't really take advantage of the TRD's stiffness if the bushings are worn out
Old Dec 13, 2007 | 05:04 AM
SUPRAboy80's Avatar
SUPRAboy80
I honestly can't remember if the TRD's came with bushings or not..hehe I forgot.... been so long.. maybe someone can chime in here...
Old Dec 13, 2007 | 03:27 PM
400DGRZ's Avatar
400DGRZ
yes, they do..
Old Dec 17, 2007 | 06:41 PM
PushinLEX's Avatar
PushinLEX
Default whooohoo
Guys, I FINALLY got my ball joints, tie rods, Daizen sway bars w/ poly brushing, and full control arm brushing kit installed.
Lemmie tell ya, she's a WHOLE DIFFERENT BEAST. Cornering is amazingly flat, and brake dive is almost completely eliminated. I am currently lowered on Tein CS V.2 as well, set to a bit softer than middle.
I lubed them up plenty inside and outside, and a good amount of the squeaking coming from my car is gone. I think the stock rubber brushings squeak as well.
In terms of ride quality, there is a bit more transferance of road feel to the cabin, but its hardly noticeably and I actually like it more. It definitely feels more responsive.
My mechanic convinced me not to install the steering rack brushing kit, so this maybe on sale in the classifieds.
You guys definitely needs theses mods.
Old Dec 17, 2007 | 09:05 PM
GSteg's Avatar
GSteg
Why would your mechanic recommend you not to install it? TMengineering, Sewell, etc all sell the steering rack bushings. I highly doubt they would push a product that isn't good for our car.
I've had mine for over a year now and I cannot have it any other way. Steering is more precise/direct without any harshness.
Old Dec 21, 2007 | 05:49 PM
slowdiver's Avatar
slowdiver
just had the Daizen CA & SR bushings installed....no more freeway steering wheel shake.....best suspension mod I have done hands down. car feels brand new again
Old Dec 22, 2007 | 12:37 AM
PushinLEX's Avatar
PushinLEX
I've actually heard that the steering rack brushing mod adds too much vibration and street bump feedback to justify the more precise steering feel. But then again, its all hearsay. My steering rack brushing was basically brand new for 79K, and I'm just holding onto it until my stock brushing goes bad for the due swap.
Lemmie add one more comment about the control arm brushing kit and Daizen sways. I've had a chance this week to put a good 100 miles on the freeway with these mods. Gawd, its like a new car. There is complete stability in 100+ mph freeway speeds, moreover; the car is definitely more responsive. There is no lag when you smash the pedal to when the torque smashes your a$$ into that fine Lexus leather. I believe this is just as much a performance mod than a suspension mod. You can take off from a dig and stop quicker way better than stock. I'm lovin this more and more
