DIY...Lower Your ISx50
Old 04-30-09, 11:20 AM
  #91
acefalcon2
acefalcon2's Avatar
i just realized that you used a small wrench to get the nuts and bolts out but i was over at mike's place with a bigger wrench... none of us got it out
Old 05-17-09, 07:26 PM
  #92
ISKIDD808
ISKIDD808's Avatar
nice DIY thread. very helpful. cant wait to drop my IS
Old 05-19-09, 08:23 PM
  #93
datplayaz
datplayaz's Avatar
Can the trunk liners R/L be removed without also removing the other trunk liners?
Old 05-19-09, 09:31 PM
  #94
eric_r_ho
eric_r_ho's Avatar
Yeah if you want to be a butcher. If it were someone else's car I would just tear away and then jam the edges in later but if it were mine, I'd do it piece by piece..
Old 07-08-09, 11:31 AM
  #95
isthrizzy
isthrizzy's Avatar
I'm going to put in my springs soon. What size gear wrench is used to remove the A-arm? I need go get a gear wrench for this job.
Originally Posted by sinister2c
next you will have to do one of two things. remove the spindle from the upper A arm or remove the upper A arm from the car. I chose to remove the A arm from the car since its easier if you have some Gear Wrenches. (the ball joint on the A arm and spindle will require brut force to dislodge.)
The A arm is attached using two 14mm bolts. The nuts on the inside of the engine bay have a holder so they will not go anywhere.
Also remove the two 10mm bolts holding the ABS line to the shock and car.
Now move the spindle off to the side, being careful with the brake lines, and remove the shock.
Old 07-08-09, 12:14 PM
  #96
edwin907
edwin907's Avatar
When I installed my coilovers I just separated the ball joint with the tool, very fast and easy.
Old 07-08-09, 12:17 PM
  #97
datplayaz
datplayaz's Avatar
it's held on with two 14mm bolt.
Old 07-08-09, 12:29 PM
  #98
isthrizzy
isthrizzy's Avatar
^Thanks bro
Old 07-08-09, 09:26 PM
  #99
sinister2c
sinister2c's Avatar
I couldn't separate the ball joint so i went the A-arm route. plus from my experience with honda's...I always end up damaging the threads or nut when i try to bang the ball joint with brute force.
Old 07-27-09, 09:36 AM
  #100
isthrizzy
isthrizzy's Avatar
Damn,
I started this over the weekend, but only got my front done so far... rear will happen this weekend.
My gear wrenches wouldn't work for the upper A arm. I followed the instructions for the Fsport springs (on the Sewell website) and it has you remove 2 bolts on the bottom... I found this to be quite easy.
The worst part (and I forgot how much this sucks) is compressing the springs. I don't have an air gun, so I was doing it with a ratchet. This is the part that caused the most aggravation for me. I'm a pretty strong guy, and it's a pain to hold the spring while compressing the last inch of the springs.
The process itself is not too difficult, but doing it while jet lagged and super tired is not recommended. Also, it's much easier if you have air tools.
Hopefully the rear goes quickly, but I'm not looking forward to it!
Old 05-10-10, 05:57 PM
  #101
akhowja
akhowja's Avatar
Default front spring install question
I am having problem taking the front strut out. Do I have to take off the sway bar bolt/link from the LCA?
Old 05-25-10, 12:11 PM
  #102
08ChrIS250
08ChrIS250's Avatar
question... will these same springs from the Original Poster fit the AWD IS?
Old 05-25-10, 01:28 PM
  #103
vntperform
vntperform's Avatar
Great DIY.
FYI to everyone in the MD/DC/VA area; if you need your shocks/struts installed in your IS250/IS350; feel free to pm as I did hellasboy (link: https://www.clublexus.com/forums/nel...all-in-md.html)
I charge $275 for the swap. PM Me if interested; sorry for going off-topic.
Old 06-05-10, 02:29 PM
  #104
SocalSo350
SocalSo350's Avatar
i can't get the front strut out...i've taken everything off mentioned up top, but the strut seems like it is still compressed and won't come out of the LCA
Old 06-05-10, 06:23 PM
  #105
SocalSo350
SocalSo350's Avatar
Nm, took the swaybar mount out and the strut dropped right out. Wow, it took me like 5 hrs to do 1 front strut. The alignment of the cap to the bottom is a PITA.
Quick Reply: DIY...Lower Your ISx50
