stoptech or brembos?
Old Apr 10, 2007 | 05:32 PM
Gernby's Avatar
Gernby
Originally Posted by Turkf26
Really not motivation just the fact that they look better and perform better. I dont track the car which is why i would only get 4 piston calipers for the front. Brake upgrades, at least to me, are something that you can do and always get something better out of it.
You are mistaken about almost everything you've said. I would only agree that they can look better. I have been tracking my cars for 15 years, and I haven't experienced a BBK yet that didn't have trade-offs. I know for sure that I would never consider one on a street car unless they were paying me.
Old Apr 10, 2007 | 05:39 PM
Turkf26's Avatar
Turkf26
CL Folding 10,000
What trade offs would that be?. I dont have any personal experiences with BBK's but all my friends that have them and DD their cars have had no problems what so ever with them. Everything worked and performed like it was suppost too.
Gernby, would you then suggest IS250 owners to find IS350 brakes and use them as an upgradable method for a DD instead of a BBK?
Old Apr 10, 2007 | 05:58 PM
Gernby's Avatar
Gernby
I wouldn't feel much better about going with IS350 brakes either unless I was also upgrading all the other hardware and electronics with it. The tradeoffs that I'm talking about would be different for every application. Worst case senario is that you put big brakes on the front only that aren't "matched" to the rest of the system. The cylinder area of the front calipers would most likely be larger, so the brake bias would be shifted even more to the front than it already is (added even more to the increased bias from larger front pads and larger diameter disks). It would also increase brake pedal travel due to the larger front piston volume (less responsive and "squishy"). ABS won't work as well for the same reasons, and depending on your driving style ... the brake pad temperatures probably won't be optimum for street use so they might dust more and / or squeal.
Old Apr 10, 2007 | 06:02 PM
Turkf26's Avatar
Turkf26
CL Folding 10,000
I guess that since the ISX50 has such a better braking system than i am used too (comming from DSM's lol) that maybe i dont need to upgrade the brakes. I wanted to do it merely for cosmetic reasons because ill be getting new rims soon and would like to fill the area behind the rim up.
Old Apr 10, 2007 | 11:23 PM
hapaboy's Avatar
hapaboy
Originally Posted by Xotic sC
ENDLESS for sure.
is there a non-blue anodized (endless) kit for the 2IS?
Old Apr 11, 2007 | 08:36 AM
DaveGS4's Avatar
DaveGS4
Administrator Emeritus
Yep, unless you track the car where you experience brake fade you very likely won't see any benefit from upgraded brakes other than cosmetics.
Plus you need to take into account that with many big brake kits you're going to need new high-disk fittment wheels that clear them, or use spacers.
I'd personally wait for the Stoptechs to get their setup correct... I think they're a better setup for the $$ compared to Brembos. I have a Brembo GT 355mm setup on my GS, but its more for show presence than any performance advantage. I've gone from 1) stock to 2) upgraded stock (synthetic fluids, stainless steel lines, upgraded pads) to 3) Supra TT calipers / rotors + upgrades to 4) the Brembo GT setup + upgrades. Honestly they all stop about the same, it's just the pedal feel and brake fade (both issues on the 2GS) that are improved. Big brakes are also typically much noisier than OEM, especially with drilled and / or slotted rotors.
Old Apr 11, 2007 | 09:56 AM
al503's Avatar
al503
You can get endless in blue, red, black, silver, and gold.
Old Apr 11, 2007 | 09:59 AM
al503's Avatar
al503
I've only had the Endless BBK so I can't speak for any other brand but they were slotted and I never noticed any noise from them.
Old Apr 11, 2007 | 01:17 PM
DEMIK's Avatar
DEMIK
i say stoptech
Old Apr 11, 2007 | 02:26 PM
ReLexin's Avatar
ReLexin
i liked my Brembo Kit on my GS, i would get the Brembo for the IS but who needs special breaks when you just have a IS250AWD. Slow POKE
Old Apr 11, 2007 | 10:52 PM
MoLexus's Avatar
MoLexus
I'll say it again, ENDLESS is the way to go.
Old Apr 13, 2007 | 05:16 AM
nabbun's Avatar
nabbun
I got AWD and i'm liking the stock brakes a lot.
The stock pads are dusty as hell (550 miles and the wheels are almost black) so I'm gonna switch to EBC Red stuff.
If I still wanna upgrade my brakes, I'd go for pedal feel first with SS lines and Motul DOT 4 fluid.
Then when it's time to replace the rotors, I'll put up slotted rotors from either company.
Greg805
Suspension and Brakes
27
Feb 15, 2012 06:42 PM
ISF4life
15
Apr 3, 2009 06:05 PM
Kevin@MVP
CL of Southern California
21
Feb 28, 2007 09:19 PM
JonnyIS350
15
Jul 24, 2006 04:28 PM
