Got an Alignment today running Tein CS
Old 09-07-05, 02:25 PM
IS0LD0UT
IS0LD0UT's Avatar
Default Got an Alignment today running Tein CS
I finally got my alignment done at the dealer today. I am running 19" Wheels with the Fat Setup with a conservative amount of drop. A little over 1 finger gap in the rear and 1.7 finger up front. After two attempts the tech was able to get all the adjustments within spec.
Old 09-08-05, 08:34 AM
IS0LD0UT
IS0LD0UT's Avatar
pics are up
Old 02-24-06, 09:41 PM
speedie
speedie's Avatar
Just wanted to give this post a bump...since it has the most legible alignment specs for a 01 - 05 GS430...
Old 02-25-06, 06:40 AM
lexforlife
lexforlife's Avatar
click on my pdf link to see my alignment from yesterday..
i just completed the last part of the daizen bushing upgrade .. i did the upper a arms on thursday.. i did the upgrade in steps to determine what made the most diff
when i removed the upper bushings they were in horrible shape .. the rubber surrounding the sleeve was sep from the sleeve it moved around by using my fingers.. it seems alignment wise the biggest help in getting my car to a acct level was after installing the upper arms
my camber was at a - 1.2 to -1.4 now its just a tick out of spec also my castor used to be way off now its within spec now keep in mind i am barely 1 finger gap if that up front with a broken finger in rear
File Type: pdf
Old 02-25-06, 08:57 AM
IS0LD0UT
IS0LD0UT's Avatar
Thanks for the bump speedie. I guess I finally was able to contribute something worth while.
Old 02-26-06, 12:50 PM
RIPP7399
RIPP7399's Avatar
Default hey lex4life
i have problems constantly with alignment. what all besides the upper a arms would i need to replace or in order as far as what made the most difference.... getting ready to replace the shocks very and could do it then.... i have h&R springs .. dropped about a 1.5 inches
Old 02-26-06, 05:41 PM
lexforlife
lexforlife's Avatar
driving wise the daizen upgrade to the castor/strut arm made the most diff but yet alignment wise doing the upper a arm bushings brought castor / sai and camber to just about within spec
on my pdf up above when i came in my camber was 1.4 then got it down to around -.9 which is acceptable seeing i am dropped about 2 + inches
PhantomV
10-13-14 11:43 AM
pizdets17
11-11-10 10:20 AM
soulific
Suspension and Brakes
06-23-10 07:27 PM
pvo
Northeast
05-03-04 10:30 AM
Shinchan
03-27-02 10:43 AM
Quick Reply: Got an Alignment today running Tein CS
