help on rear trd sways...
guys, can you tell me how to take out the stock subframe on our car? i had trouble taking it out after i took 4 bolts that holds it in place. it moves but for some reason, it wont come off. im trying to install my TRD rear sways but as of now, i can't finish the job. the stock subframe wont drop down as it looks like it's being held by another bolt or something. there is a bolt in the middle of the subframe. do i need to take that off as well?
if anyone can direct me, i'd appreciate it.
in the club lexus library...
Sway Bar Swap From MKIV Supra TT To SC 300 (adobe PDF)
https://www.clublexus.com/index.php/...To%20SC300.pdf
When I put my parts on, I just swapped the supra parts on one side at a time, left the subframe right where it was.
The mufflers will need to be removed to replace the swaybar.
