Help: Spring drop's and how much they drop
Old 01-29-04, 08:33 PM
Blue98Gs3
Blue98Gs3's Avatar
Default Help: Spring drop's and how much they drop
I'm looking into getting the l-tuned suspension and was wondering what the drop was front and rear for the l-tuned and also for other springs/shocks.
Thanks guys
Old 01-29-04, 10:20 PM
GS4Will
GS4Will's Avatar
l-tuned , ~1"
HR, ~1.2" f+r
most JDM springs, 50/30mm, ~1.6"/1.25"
Old 01-30-04, 05:17 AM
Blue98Gs3
Blue98Gs3's Avatar
So your espelir springs are like that? 1.6 front, 1.25 rear? That would work out perfectly since i have a huge system in the back. How is the ride with espelir?
Old 01-30-04, 11:12 AM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
The Espelirs are said to ride pretty well, of course 20s eat up some of the comfort but hey
I have seen these installed and they give a very aggressive low look, with the system though the rear will probably be eve with the front (or maybe a little lower), thats the tradeoff of springs and systems!! Maybe you wanna think about coilovers for that reason. Brand New espelirs and Bilsteins will probably run you about 650-750 and Bilstein coilovers are about 875!!
Check out this pic of a white GS on Espelirs, this guy doesnt have a system though!
Old 01-30-04, 11:47 AM
LEXISM
LEXISM's Avatar
since where on this topic what springs aside from Ltuned and Eibach can we use to drop our cars but not need to worry about the alignment and which is lower? thanks anyone
Old 01-30-04, 12:28 PM
D2-AUTOSPORT
Former Sponsor
I think your asking what goes lower than Ltuned/Eibach but still is able to be corrected for camber, right?
Espelir -1.6
Tanabe- 1.6
Tein- 1.8
Daizen- 1.9
I have only seen the 1st 2 in person, and they are plenty low, I think if you stay above 2" you should be okay for factory camber correction!
Old 01-30-04, 03:31 PM
PHML
Master Thread Closer!!
PHML's Avatar
Don't forget H&R Sport ~ 1.5 drop
Old 01-30-04, 03:37 PM
LEXISM
LEXISM's Avatar
great info now how do they ride?
Old 01-30-04, 03:41 PM
D2-AUTOSPORT
Former Sponsor
Thats where I have to bow out, I have never taken a ride on any of the above setups? I know the H&Rs are said to be pretty rough and the Espelirs are said to be real comfy ( the guy that has the white car told me)
Old 01-30-04, 06:01 PM
GS4Will
GS4Will's Avatar
Espelir has ~the same spring rate as stcok ones
Old 01-30-04, 06:06 PM
Blue98Gs3
Blue98Gs3's Avatar
GS4Will, I think I will be going with the espelir's and the ltuned shocks, sounds like this will get me the best drop and best ride quality, is this correct you guys?
Old 01-30-04, 06:09 PM
GS4Will
GS4Will's Avatar
yeah, quite a few GS bros have that set up..looked great and rides comfy
Old 01-30-04, 11:02 PM
RNM GS3
RNM GS3's Avatar
Espelir springs will give u a nice drop...... It will def eliminate almost all the wheel gap.
As far as ride comfort, its just a tad more stiff than stock, you gotta remember ur putting on different shocks not only springs, which also effects ride comfort. When i had my 16in wheels on, there was almost no difference in ride comfort between stock setup and the espelir/ltuned setup.
For me the 18in wheels and NYC roads is what effects my ride comfort the most.
BTW i also got the springs from GS4WILL.
Old 01-31-04, 08:06 AM
D2-AUTOSPORT
Former Sponsor
Good point man, its the shorter sidewall that really changes things, when I took my 20s off an came to BK, I could believe how nice my car rode! Then I put them back on rough rider once again!! LOL
Old 01-31-04, 08:21 AM
bluelex
bluelex's Avatar
the espelir drop looks much lower in person and when driveing it get really low... the ride is ok......tho..good luck
Quick Reply: Help: Spring drop's and how much they drop
