How an Engine Works - 3.5L V6 Teardown!
Old 07-23-19, 03:18 PM
speedkar9
speedkar9's Avatar
Default How an Engine Works - 3.5L V6 Teardown!
I took apart the engine on my Infiniti G35 and would like to share with you all the tear-down and how it works:
This is Nissan / Infiniti’s popular 3.5L VQ35DE V6 engine, used in many vehicles since the early 2000’s.
Here’s the engine, on the stand and the major components that surround it:
On top of the engine are the ignition coils. There are 6 total in this V6 engine, three on each bank:
With all the accessories, hoses, brackets, belts and mounts removed, here’s what the front of the engine looks like after removing the access covers on the timing cover:
The oil pan was removed next, where we have a look at the oil pump and pickup tube. There’s two bolts under here that secure the front timing cover:
Here’s the timing cover removed, with all the associated timing components. The timing system is responsible for correctly positioning the intake and exhaust valves within each cylinder during their respective position in the combustion cycle. The system is driven by the crankshaft, up through a timing chain, then across two intake camshafts. Auxiliary chains drive the exhaust camshafts.
With the valve cover removed, we have a look at the intake and exhaust camshaft. Each has a lobe on it that push down on the tappet to open the valve.
The rear timing cover is removed next:
The camshaft cap (which also houses the VVT-I solenoid and auxiliary timing tensioner) is removed next:
There’s 8 head bolts per head to remove and then the engine head (that holds the valves, spark plugs and camshafts) can be removed from the engine block revealing the pistons:
Underneath the block, with the upper oil pan removed, we have the crankshaft, held on by its main bearings through a bearing holder:
I busted my socket removing these external torx e14 main bearing bolts with an impact!
Here’s what the crankshaft looks like inside the engine block. It’s the heavy hauler in an engine, and is driven by the pistons that move in a crank-slider like mechanism. Once piece of heavy steel! Notice how the pistons are offset for each bank for this V6 engine.
Here’s the piston removed and its components:
This is the rear main seal that separates the oily part of the engine from the transmission outside:
Crankshaft removed:
The cylinders are lined with steel since the block is aluminum. You can also see the oil jet sprayer that coat the cylinder walls for lubrication.
Here’s a look under the engine head at those valves. The intake valves had quite a bit of carbon buildup.
And this is the valve removed, with its return spring:
And that’s pretty much all the components that go into an engine!
Enjoy
speedkar9 is offline
Old 07-23-19, 03:31 PM
Hoovey689
Hoovey689's Avatar
Ah the legendary VQ35 motor!
As always, thanks for the detailed lessons!
Hoovey689 is offline
Old 07-23-19, 04:29 PM
mmarshall's Avatar
Thanks for sharing, speedkar......excellent post as usual. That engine had a great reputation.....at one time, considered one of the World's 10 Best engines by several different automotive organizations. As you illustrated, it has a nice steel timing chain instead of those crap-rubber timing-belts that wear out, break, and/or have to be replaced every 5 years or so, driving up maintenence costs, especially with transverse-mounted engines where they can be difficult to reach.
The carbon build-up on the valves that you illustrate can be caused by several different sources (among them Direct-Injection), but a very common reason is people using cheap, cut-rate-brand gas, which is OK as far as octane is concerned, but often doesn't have the necessary amount of detergent additives to keep deposits from building up (It's cheaper for a reason). That is a subject I have cautioned about a number of times, in previous posts. In general, the Tier-One brands of fuel will have enough detergent in them to keep deposits from building up. I've generally had the best luck with Chevron's Techron/Techrolene and Shell's V-Power additives, but, for reasons I don't know, Chevron fuel is no longer available in the immediate area where I live...they closed their Northern Virginia stations and/or converted some of them to the Liberty brand.
mmarshall is offline
Old 07-23-19, 06:49 PM
Sulu
Sulu's Avatar
Thanks for the great write-up!
I have one question: I assume you meant "VVT" rather than "VVT-I"?
"VVT" is the accepted abbreviation for Variable Valve Timing (without regard for any automaker's specific technology).
"VVT-i" (Variable Valve Timing with Intelligence) is the name given to Toyota's specific variable valve timing technology. Nissan does not use Toyota technology.
Sorry for nit-picking.
Sulu is offline
Old 07-23-19, 11:46 PM
I watched that whole thing--I assume that engine was toast?
I had a 2002 Infiniti I35 with the 255hp version of that 3.5, it was a smooth beast. The thing was geared terrible though so it wasn't as quick as it should have been.
AJT123 is offline
Old 07-24-19, 06:27 AM
mmarshall's Avatar
That was probably one of the reasons why Nissan switched to CVTs for a lot of its products.....though I never had much faith in the reliability of those early CVTs (particularly with larger engines) and history, more or less, bore that out.
Old 07-24-19, 01:30 PM
Yep, and that's why I have no desire for any Nissan product anymore. I can't stand CVTs; I don't like the way they drive. It's a deal breaker for me.
AJT123 is offline
Old 07-24-19, 03:43 PM
jwong77
jwong77's Avatar
@mmarshall as far as I know, the VQ motors of that era used port injection not direct injection.
jwong77 is offline
Old 07-24-19, 04:13 PM
mmarshall's Avatar
Yes, I just listed DI as one of many things that can cause carbon-buildup. But a more common cause is simply sub-standard gas brands.
Old 07-24-19, 04:20 PM
I also had a 97 Maxima with the original 3.0 VQ that everyone gushed about....that motor was a gem. Felt way stronger than 190hp. It was a manual, too. Other than my LS430 it was by far my favorite car I've had.
AJT123 is offline
Old 07-24-19, 07:45 PM
speedkar9
speedkar9's Avatar
Thanks. Yep the infamous VQ35DE.
Yeah thanks for the correction, it should be VVT.
Thanks. It was indeed an award winning engine. Its too bad everything else they were attached to didn't hold up as strong.
Lets just say the rest of the car wasn't in road worthy shape to be worth fixing. The engine did run fine, but I have other plans for it
One day I hope to get a CVT to take apart and do a teardown on....
Stereorob
22
08-07-20 05:37 AM
fongsIS350
05-05-18 01:00 PM
xcharlesy
06-19-11 12:52 AM
kevenhang
06-05-08 09:06 AM
Rash
09-17-07 01:04 PM
Quick Reply: How an Engine Works - 3.5L V6 Teardown!
