Hybrid Technology Unique topics related to the LS600h L model hybrid drivetrain and other features/options found only on the LS600h. Please use the main 4LS forum for discussion about shared components with other fourth generation LS models.
LS600HL DIY Hybrid Battery replacement(using Prius cells)
Old 07-14-19, 09:23 AM
argonfatl
argonfatl's Avatar
Default LS600HL DIY Hybrid Battery replacement(using Prius cells)
I have 08 LS600HL with 195k. Battery started to show errors.
I was thinking to rebuild battery but it’s impossible to find 14v original cells. Therefore I’m planing to use 40cells from Prius to get 288v(6.5 ah)
What do you think about this idea?
3GSShoe (07-16-19)
Old 07-14-19, 09:56 AM
argonfatl
argonfatl's Avatar
Step #1
I got 40cells from EBay
Got 4 brackets to hold cells compressed.
Got 5 chargers to check cells capacity.( 3 cycles discharge1A-change Auto1-6A)
Old 07-14-19, 12:53 PM
argonfatl
argonfatl's Avatar
Originally Posted by FunFact
That isn’t how batteries work. Did you even assess the max draw they can take? You can’t just slap batteries in the achieve the same voltage and KWh rating and think it’s okay. The motors in the LS will draw way more amperage.
All my research shows that it’s same cells and ls600 just has double cell. Gs400h use 40cells like in Prius
Old 07-14-19, 04:09 PM
jdanielca
jdanielca's Avatar
lets just assume he has some experience with electrical engineering and knows what he's doing.
Old 07-14-19, 04:56 PM
KYLS
KYLS's Avatar
I'm certainly interested to know how it works out. Please keep us posted, with pictures of the swap. Thanks!
argonfatl (09-05-19)
Old 07-15-19, 06:15 PM
JiffyPop
JiffyPop's Avatar
Old 07-16-19, 08:36 AM
sdls
sdls's Avatar
That is definitely very nice that you can use Prius cells. WAY better than having proprietary $10,000,000 cells only for this model! And I love the threaded rod cell compressor concept, clever and cheap!
Old 07-16-19, 05:46 PM
sktn77a
sktn77a's Avatar
I'd google all of the hybrid battery refurbishers and contact them to see if they're producing (or even working on) LS batteries. Prius batteries have plummeted in price in the last couple of years and I'm guessing these guys are working on an LS replacement.
Old 07-16-19, 06:20 PM
3GSShoe
3GSShoe's Avatar
I see no reason why toyota would make different batteries unless they are newer or older generations
Old 07-18-19, 01:39 AM
JimmyDee
4th Gear
JimmyDee's Avatar
I'm considering the same idea. Could you post a pic of two small cells end to end beside one of our longer cells so we can see if they'll fit once they are joined?
I guess if the packs themselves won't physically fit, it would be possible to open the packs and swap out the individual cells. It'd be a bit of a mission though!
Old 07-18-19, 08:05 AM
cochiseg
cochiseg's Avatar
how about the solid state batteries announced for 2020, could these offer an upgrade to the hybrid systems?
Old 07-31-19, 06:41 AM
argonfatl
argonfatl's Avatar
Old 07-31-19, 06:45 AM
argonfatl
argonfatl's Avatar
Update. Prius battery compression will not work because it’s too big. I will order metal one to fit in.
Old 07-31-19, 06:47 AM
argonfatl
argonfatl's Avatar
Diagram for metal holders
Old 08-04-19, 07:10 AM
sdls
sdls's Avatar
I'm tempted to print and mark up your drawing in red ink. It doesn't meet ASME Y14.5M-1994 standards.
Quick Reply: LS600HL DIY Hybrid Battery replacement(using Prius cells)
