How To Get All Doors to Unlock at Once
Old 04-19-19, 09:12 AM
zmoneyJD
zmoneyJD's Avatar
Default How To Get All Doors to Unlock at Once
When I unlock my car and press the unlock button on the remote, only the drivers side opens and the rest of the doors emailed locked. Either I have to press he unlock button on the remote again once or twice, or unlock the car for my passenger once I sit inside.
is there a way to make it so that one press or the button on locks all doors?
Old 04-19-19, 10:23 AM
a1rh3adsz
a1rh3adsz's Avatar
Yes, you can change the setting in the menu. You can pretty much personalize to how you like it
Old 04-19-19, 11:06 AM
zmoneyJD
zmoneyJD's Avatar
where is that???
Old 04-19-19, 11:08 AM
HOMER350
HOMER350's Avatar
I changed my settings to unlock all doors however that only works when i unlock via door handle sensor.
My key fob still requires double-press to unlock all doors.
I figure I have to address with dealer as it may be a "dealer only" programmable option. Or did I miss something?
Old 04-19-19, 01:20 PM
arentz07
drives cars
arentz07's Avatar
Received 3,510 Likes on 1,806 Posts
You can do it through the infotainment system. No need to go to the dealer. For instance, I have it set to unlock all the doors when I unlock the car by touching the door handle.
Old 04-19-19, 02:40 PM
HOMER350
HOMER350's Avatar
Yes mine too as I mentioned above.
But the question was how about the key fob? Can it be set to allow 1 push to unlock all doors.
Old 04-19-19, 04:33 PM
arentz07
drives cars
arentz07's Avatar
Hm, yeah I guess those aren't the same setting.
Meh, I found the intelligent access way easier.
Old 04-19-19, 04:49 PM
HOMER350
HOMER350's Avatar
Yeah that's me 9/10 times.
But gotta love pushing buttons lol (but only once, of course ha)
Old 04-19-19, 07:54 PM
a1rh3adsz
a1rh3adsz's Avatar
when i changed the setting my key fob only required one click and when i touch the door handle all the doors unlock. All that from the setting menu change. And yes the double click is standard and you change that using the navi system or can be changed by the dealer. There is a chart showing what can be changed, what is standard from factory and how it can be customized either by dealer or both dealer and you.
Old 01-04-20, 01:59 PM
momak
momak's Avatar
This is how to change the setting. Get in the car while its off. Hold the unlock and lock button for 5 seconds. You should see an image of an icon of the car with all 4 doors open. There will also be 3 chimes and you are done. From now on, when you use keyless entry, all of the doors will open. Enjoy.
Jazzrock (01-04-20)
Old 01-04-20, 02:10 PM
arentz07
drives cars
arentz07's Avatar
Interesting. Why not use the infotainment system as mentioned above?
momak (01-04-20)
Old 01-04-20, 02:16 PM
momak
momak's Avatar
I wasn't aware of the infotainment system method. I think using the key to change the setting was a breeze. Whatever is easier really.
Old 01-04-20, 02:20 PM
momak
momak's Avatar
Does anybody have a link for a list of all the personalized settings that can be applied to a 2015 lexus is and how to do so? That would be something fun to browse through.
Old 01-04-20, 09:11 PM
arentz07
drives cars
arentz07's Avatar
While sitting in the drive thru line, I found the setting. Just go to Setup, Vehicle, and then Door Lock Settings.
Batmobile
10-20-18 11:41 AM
starbai
08-27-15 07:30 AM
akharitone
ES - 5th Gen (2007-2012)
07-27-10 11:02 AM
time4deco
07-28-09 06:29 PM
draco
12-13-08 04:48 AM
Quick Reply: How To Get All Doors to Unlock at Once
