Maybe a crazy exhaust idea
Old 03-16-19, 09:50 AM
Cronus1995
Cronus1995's Avatar
Default Maybe a crazy exhaust idea
I have an idea that I'm not sure is legal or not.
I want to upgrade the factory exhaust to a 2.5 inch diameter true dual setup. However because I live in California I want to keep the secondary catalytic converters.
So the idea is yank the midpipe off, chop the secondary cats off, and modify the openings to accept 2.5 inch tubing.
I haven't been able to find anything that says it's smog legal or not. Can anyone advise me?
Old 03-17-19, 09:52 PM
whitebeast
whitebeast's Avatar
according to state's smog law, any cat after the second o2 sensor will not affect the smog check condition. My cousin own a shop (including smog) had verified me about it already.
Old 03-18-19, 09:56 AM
bakalag
bakalag's Avatar
Keep the secondary cats but chop off? Are you putting them back on?
I cut off from after the secondary cats and went x-pipe to true dual, passed smog with no issues.
whitebeast has heard my car =P
Old 03-18-19, 10:34 AM
Cronus1995
Cronus1995's Avatar
Sorry let me better explain.
I want to run 2.5 inch pipe from the primary cats to the secondary cats, modify the openings of the secondary cats to accept 2.5 inch, then continue running 2.5 inch all the way to the rear.
Old 03-18-19, 02:30 PM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
This is a 350, yes? And what do you plan to do with the mid out to the tail? I'd suggest you include a crossover pipe positioned as far forward as possible to reduce the chances of droning.
This Borla product comes to mind...
this is 2.5" but they make the same in 2.25"
https://www.borla.com/products/proxs...t__400493.html
Old 03-18-19, 02:58 PM
Cronus1995
Cronus1995's Avatar
It's a 350. Basic break down will be exhaust manifolds, 2.5 inch tubing, secondary cats, borla xforce muffler with a built in crossover, more 2.5 inch tubing, magnaflow mufflers in the rear.
Should be a nice flowing quiet exhaust. As long as it will pass visual smog I'm happy.
Old 03-28-19, 10:15 AM
bakalag
bakalag's Avatar
I had issues with spacing when I did mine, hope yours comes out nice, good luck!
Old 03-29-19, 11:52 AM
2013FSport
2013FSport's Avatar
Having ran V8's most of my life and never had drone issues, anyone care to repeat the past?
Simple setup; axe the secondary cats for the Borla crossover 2 in, 2 out. Fit some mufflers near the crossover about where the resonators are now and the rest is straight pipes to the tips. No rear muff past the axle.
So the question is, is it the firing order causing the drone or will getting the muffler back by the trans have it act as a resonator? And with the crossover, I think it will work.
Passing smog inspection, maybe not for the visual part.
Thoughts?
Old 03-29-19, 11:57 AM
Cronus1995
Cronus1995's Avatar
Well that's the kicker. I want to be able to pass inspection.
So at least the shells of the secondary cats need to be in place.
tnilc
RC - 1st Gen (2015-present)
06-02-19 11:22 PM
RCFCoop
RC F (2015-present)
27
04-08-19 05:38 AM
Gc3p0
Performance & Maintenance
07-11-14 03:55 PM
mrshabo
19
11-25-04 03:19 PM
CmputerWiz
06-29-01 12:15 PM
Quick Reply: Maybe a crazy exhaust idea
