Sudden Increase in Fuel Consumption
Old 02-22-19, 07:25 AM
junX3
junX3's Avatar
Default Sudden Increase in Fuel Consumption
Hi guys
I have recently used the techron concentrate plus to clear some of that carbon
However, I noticed my fuel consumption went up significantly - enough for me to take notice
it was pretty stable at 22.6mpg (metered) / closer to 21mpg (actual) but it went to close to 19mpg (metered) /18.8mpg(actual)
this is pretty much the same daily drive and traffic
is there anything I should be worried about?
Old 02-22-19, 08:17 AM
mcomer
mcomer's Avatar
Does that additive/cleaner have alcohol in it? Well documented fact that surfaced when
E-85 (85% alcohol / 15% gasoline) became available was that while the price was lower
per gallon your mileage would go down 30%. I would continue to record your results and
would expect a return or hopefully an improvement to your baseline ratings. Outside chance
you are...um...checking out the performance changes and...well...driving a bit harder?
Old 02-22-19, 10:52 AM
timmy0tool
Forum Moderator
timmy0tool's Avatar
we aren't suppose to run E85 on these engines as they are not designed for it!
OP, what model is your IS? 250 or 350?
Old 02-22-19, 11:02 AM
MikeFig82
MikeFig82's Avatar
Originally Posted by junX3
Hi guys
So you put the cleaner through the gas tank? Or vacuum line to clean up the carbon on the valves? The only way to clean the valves is through the vacuum. Gas additive won't help for the 250. For the 350 then it will do some good maybe.
Old 02-22-19, 06:03 PM
junX3
junX3's Avatar
Unhappy
many thanks for the kind advices
I'm using the techron concentrate plus, not sure if it contains alocohol but the 2 main ingredients are Distillates, hydrotreated light and Polyether amine (info gotten from the SDS and these 2 makes up to 90% of the 12oz bottle
definitely hoping that, I am not too concern about the fuel economy to be honest, just wondering if the spike in that could be pointing to a more major issue internally - o2 sensor or fuel pressure? (i do have a bit of fuel smell particularly in the rear passenger seats during the first 10-15min of drive but that occur before the techron/fuel consumption spike)
I am just in my 3rd tank after the techron and I ll continue to see if it changes - 1 thing I noticed as well the tank average went 22.6 so did the average FC, I thought that that usually takes much longer to "average" out
my apologies for missing that out...we only have the 250 in my country
it was done through the gas tank, 355oz in 11.9gal, I may have diluated even more as I pump a full tank after
Old 02-23-19, 09:29 AM
2013FSport
2013FSport's Avatar
Received 1,535 Likes on 1,277 Posts
Excessive idle time, cold weather, lower tire pressure, dirty air filter, dirty MAF, and worn spark plugs all contribute to reduced mpg's.
That small amount of additive likely has little to do with the situation. I run that product 3x a year to remove moisture. And although mines a 350 mpg's drop in the winter about 1.25mpg.
Old 02-24-19, 06:02 AM
junX3
junX3's Avatar
yep..i am more worried it may be the maf or o2 sensor or the recalled fuel pressure sensor...because I did get some fuel smell from time to time particularly at the rear seats
I am not sure with sensors if u get some rough idling or engine cutting off, eg more obvious symptoms but I am not getting these
I have changed the spark plugs and air filter less than 5k miles ago..and I do checks on tire pressure time to time...no winter where i stay too
i guess all i can do is monitor for the next few tanks or so
MSterling
ES - 7th Gen (2019-present)
149
02-29-24 04:16 PM
Cwang
10-20-18 02:32 PM
mlo1956
NX - 1st Gen (2015-2021)
07-02-17 01:28 PM
Matty2768
08-02-12 12:00 PM
350Dave
ES - 5th Gen (2007-2012)
12-07-07 03:27 PM
Quick Reply: Sudden Increase in Fuel Consumption
