TVD Service Interval(?!?!?!)
Old 02-18-19, 08:59 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,854 Likes on 2,337 Posts
Default TVD Service Interval(?!?!?!)
I just took a long look at the maintenance requirements for the TVD on the 2015 RC F and discovered there is not even one recommended differential oil change period, and the TVD clutches (separate units for left and right) use WS ATF and also have no mention whatsoever in the maintenance schedule. TIS does have a defined procedure for changing these fluids, unlike the AA80E transmission with its "lifetime" fill from the factory which has no clearly defined procedure for changing the fluid. But there is no recommended change interval.
Does anyone else see this as odd?
FWIW, non-TVD differentials have a 60k mile oil change interval.
BossMoss (02-20-19)
Old 02-19-19, 05:15 AM
Mingofish
Mingofish's Avatar
I’ve changed mine at 10k, then again recently at 22k.
I wanted to get the break in debris out plus for curiosity.
At 10k it looked decent. Not much metal in it, unlike the main diff which had a good bit of metal flakes and general sludge like build up.
The second time, 12k miles and like 10 or so track days more, fluid literally looked brand new in the diff and the two tvd pods.
Although I didn’t test the oil, felt pretty good about it.
Prob wont change it again till like 50k.
The following 2 users liked this post by Mingofish:
Apone (02-20-19), BossMoss (02-20-19)
Old 02-19-19, 06:52 AM
LRCSALES
LRCSALES's Avatar
Had a friend blow his up, because he is very hard on the car break JUST before 50k miles. The replacement was going to cost over $20,000 if he didnt have it under warranty
Old 02-19-19, 06:57 AM
LRCSALES
LRCSALES's Avatar
s
BossMoss (02-20-19)
Old 02-19-19, 06:58 AM
LRCSALES
LRCSALES's Avatar
not sure on just the clutch packs or if they come with the shaft, but if together looks like 2300 to 2600 each .
Old 02-19-19, 11:39 AM
05RollaXRS
05RollaXRS's Avatar
Received 2,423 Likes on 1,744 Posts
Holly! That thing is expensive.
Yeah, I would like to find out as well when I should have the TVD serviced. It does not make sense to have the same fluid for the lifetime (I believe, M3 M-DCT fluid was the same thing, but owners got the fluids replaced anyway). I will check with the dealership for the upcoming service/maintenance inspection.
Old 02-19-19, 11:56 AM
LRCSALES
LRCSALES's Avatar
yes my friend was very lucky. but like i said he drives like KEN BLOCK, on the good side the motor still pulls hard!
05RollaXRS (02-19-19)
Old 02-19-19, 07:31 PM
Mingofish
Mingofish's Avatar
Hahaha. You mean he wishes he drives like Ken Block.
I bet if he had serviced those clutches around 10k and got out the break-in crud, the results would be very different.
LRCSALES (02-20-19)
Old 02-20-19, 03:21 AM
Teutonic
Teutonic's Avatar
I'd be curious to know that as well. No service seems odd on it considering its cost and that it does experience wear.
Originally Posted by LRCSALES
s
That's insane! It really makes me consider getting another warranty after the LCertified warranty runs out in a few years. Although a quick search on Ebay shows a unit for $2,500.
Any idea what the symptoms were and what the failure mode was?
Old 02-20-19, 08:15 AM
LRCSALES
LRCSALES's Avatar
ill have to ask but im pretty sure he was out doing highway pulls after a cars and coffee and was suddenly stranded on an onramp. He dashboard lit up like Christmas though . Im sure he ignored some chattering at low speeds
MCB1970
MCB1970's Avatar
Looks like amayama has it for $7254. Not sure what shipping would cost. https://www.amayama.com/en/part/toyota/4110029005
Old 02-20-19, 12:36 PM
Apone
Apone's Avatar
That is unexpectedly expensive.......
Old 02-20-19, 03:21 PM
gobrowns33
gobrowns33's Avatar
It can't be that expensive...that would make the Performance Package like a 20k option!
Old 02-20-19, 03:58 PM
Deanrcf
Deanrcf's Avatar
Wouldn't that fall under the 72mo/70k powertrain warranty or does he have over 70k on the odo?
Old 02-20-19, 08:06 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
https://www.google.com/search?q=41100-29005
Check it and cry. This is for the entire unit with both left and right electrically managed clutches. $19+k.
Ay-nako (09-22-20)
Quick Reply: TVD Service Interval(?!?!?!)
