NX - 1st Gen (2015-2021)
Current Miles on your NX?
Old 02-15-19, 04:14 AM
catchtanya
catchtanya's Avatar
Default Current Miles on your NX?
I have a 2015 with almost 80k miles which I am sure to hit after a drive to Nashville from DC next week. Curious what other owners have had and if they've started seeing any issues? Ive replaced brakes, tires and had a side view mirror replaced to date. Love this car!
How many miles are currently on your NX. Anyone in the 100k mile club yet?
Tanya
Old 02-15-19, 06:12 AM
brook41
brook41's Avatar
61 k on my 2016 base mostly highway, OE tires(Dunlop) 5/32 tread, no significant problems . I had some loose plastic shields causing noise at highway speeds , and a small crack on wheel well liner that’s it. All maintenance done, oil andbrake fluid changes, plugs at 40k, filters, tire rotations by myself. I plan on doing a trans drain and fill in the near future.
catchtanya (02-15-19)
Old 02-15-19, 08:08 AM
Danny200t
Danny200t's Avatar
2015 NX, 38,800 KM / 24,000 Miles
Old 02-15-19, 09:54 AM
catchtanya
catchtanya's Avatar
Danny! You barely drive it! LOL
Old 02-15-19, 10:10 AM
ukrkoz
ukrkoz's Avatar
2015 NX200t/ 33600 miles. Just had warranty required brake fluid flush.
otherwise, unknown clunk in suspension going over bumps/potholes. Lexus took 10 days first time to figure it out, replaced both front struts, then put "suspension ears" on and ended "re-tightening all bolts". Clunk went away and came back about a month later and is slowly getting worse. I'll bring it back in March, let them have it. "self loosened bolts" does not appeal to me as explanation.
Old 02-15-19, 11:02 AM
brook41
brook41's Avatar
Ukrkoz, if you don’t mind me asking,what did the dealer charge for brake flush?
Old 02-15-19, 12:02 PM
olgzr
olgzr's Avatar
We have 37,000 miles on a 2015. It was purchased in July of 2015 as a demo with 4550 miles on it. Our only problem was a plastic bag stuck on the exhaust pipe causing a burning smell. (Can’t blame Lexus on that one).
catchtanya (02-16-19)
Old 02-15-19, 01:15 PM
jonnyyaa
jonnyyaa's Avatar
almost same as Danny - 37000 km (23000 miles) on 2015 executive
Old 02-15-19, 02:50 PM
Danny200t
Danny200t's Avatar
I drive it everyday, but my daily commute is only 20km and so i barely drive over 1000km a month lol.
Old 02-15-19, 03:20 PM
dacommitte
dacommitte's Avatar
64K on my 15 F-Sport. Replaced front brake pads and on second set of tires, nothing else done other than oil changes every 5K and tire rotations every 10-15K. Planning on changing the original plugs within the next couple of weeks.
Old 02-15-19, 09:52 PM
TechNut
TechNut's Avatar
2016. Three years this very month. 10,600 miles. Zero issues, but not surprising at such low mileage. Quite a bit of road noise compared to other Lexuses we have owned - but that is just the nature of the vehicle.
Old 02-16-19, 03:49 AM
catchtanya
catchtanya's Avatar
I found the same to be true with the standard tires that they had. I had michelins at first, ran into an issue when them shaking so the local dealership swapped them out for Yokohamas. I dealt with those for a while and then when it was time to replace them went with a cooper brand tire, better, not great. Just this past week I took the risk and put on the Vredestein tires, and surprisingly both the ride and the noise level have greatly improved! i was quite surprised and shocked!
VREDESTEIN
QUATRAC 5
Old 02-16-19, 05:11 AM
chezgk
chezgk's Avatar
04/2015 NX200t @ 28,000 Km / 17,500 mi
- Oil and filter changed every 5k Km
- Air filter replaced once at 10k Km
- OEM Akebono front pads wore out after 11k Km, replaced with EBC Yellows (wore out after 25k Km), subsequently replaced with Hawk HPS 5.0
- OEM rear pads half worn at 11k Km, replaced with genuine Toyota part and still ok
- OEM brake fluid boiled during spirited driving and was subsequently replaced with aftermarket DOT4 via Techstream. Gets replaced annually or whenever it boils, whichever comes first.
- Hit nasty pothole at around 24k Km. Caused annoying clunk. Replaced lower control arms, ball joints, outer tie rods, rack ends, stabilizer links, and front left wheel bearing to no avail. Replaced all AVS shock absorbers to no avail. Turned out the pothole just knocked the F-Sport lateral damper loose. Now have an extra set of AVS shock absorbers. lol
- Replaced original tires with GT Radial Champiro HPYs (paired with aftermarket wheels) and eventually installed Toyo Proxes St-IIs since the GT Radials were about to expire.
Old 02-16-19, 05:18 AM
catchtanya
catchtanya's Avatar
Im pretty sure plugs are every 40k miles. Check the maintenance guide.
Old 02-16-19, 06:54 AM
ukrkoz
ukrkoz's Avatar
Oh gosh... I went to Toyota as someone said that it's cheaper to do at Toyota than Lexus. No. Toyota may work on Lexus but charges Lexus price... I think he gave me discount for me being avery nice guy and it all ended in somewhere around $170 or so. He was actually very surprised, why do I even insist on doing this, as fluid was immaculate. But, it says to do so in maintenance guide, I am not giving them any excuse to void warranty.
I just went through my bank account, it won't pull "toyota" in search.. I think it was originally $190 something then he discounted it... looked like had mercy over me... guy was pretty astonished why BF has to be changed at such low mileage, ha ha. Auburn Toyota, WA.
Quick Reply: Current Miles on your NX?
