265/65/18 tires
Old 02-11-19, 07:05 AM
Madtiger
Madtiger's Avatar
Default 265/65/18 tires
I have no plan on getting anything bigger than this size. Quick questions:
1. Does it rub at extreme steering angles? And when fully compress?
2. Does it fit under in the spare tire area?
I understand that it will slightly affect the speedometer and mileage.
Old 02-11-19, 07:25 AM
CobraSpdRH
CobraSpdRH's Avatar
I can tell you it doesn't rub at all, at least for my 265/65/18 Nitto Terra Grapplers.
I didn't replace the spare so can't comment on that.
Madtiger (02-11-19)
Old 02-11-19, 07:41 AM
GoHuskers
GoHuskers's Avatar
I also have 265.65.18 Defender LTX and it fits perfec, no rubbing whatsoever. I didn't replace the spare so I can comment.
The following 2 users liked this post by GoHuskers:
Madtiger (02-11-19), Yona (02-12-19)
Old 02-11-19, 07:49 AM
ASE
ASE's Avatar
+1 on the Michelin’s ... fills out the wheel well perfectly with absolutely no rubbing. Did not replace spare ... figured spare would only be used for short distance where air-down would address any issues if absolutely necessary ... we’re only talking a 1/2” difference.
Madtiger (02-11-19)
Old 02-11-19, 08:37 AM
Madtiger
Madtiger's Avatar
I want to replace spare because difference in diameter may be problematic for VSC......and if you’re off-roading and have CRAWL, then that can really screw up CRAWL i think.
Old 02-12-19, 05:14 AM
Airpirate
Airpirate's Avatar
My KO2's in that size don't rub. My guess is that these would fit in the spare location, but I can't confirm.
Old 02-12-19, 06:11 AM
Madtiger
Madtiger's Avatar
Very nice looking!! I would love KO2 but i am afraid of its Load Range E...and 51 lbs per tire. How’s the ride compare to stock? Gas mileage?
ballistice (03-09-22)
Old 02-12-19, 06:16 AM
Madtiger
Madtiger's Avatar
Anyone have Continental TerrainContact AT?? I know that these are “mild” AT tires but from TireRack reviews, they are excellent dual purpose tires. I spend most of my time on-road/highway.
Old 02-12-19, 06:49 AM
MCDavis
MCDavis's Avatar
No experience with that specific tire, but I've not been overly impressed with the Conti's I've had on other vehicles...usually the OEM offering.
The best highway tire with some offroad use is hands down the Michelin Defender LTX (previously the LTX M/S2)
Old 02-12-19, 06:51 AM
Madtiger
Madtiger's Avatar
Are the Defenders quiet??
Old 02-12-19, 07:03 AM
GoHuskers
GoHuskers's Avatar
a little louder than latitude but better in any other categories. Hopefully it will last longer than the 31k miles I got from my Latitude.
Old 02-12-19, 07:32 AM
Airpirate
Airpirate's Avatar
I have carefully documented my mileage, and it is running around 15 in town and 20 at 65mph on the freeway. 19 above 65mph. Therefore, whatever penalty exists with the KO2's must be minimal. These tires are noisier than the stock Pirelli tires, but not by much. I don't mind the tire noise at all, considering the improved look and traction.
Madtiger (02-12-19)
Old 02-12-19, 08:08 AM
MCDavis
MCDavis's Avatar
That's one of their pro's...stupidly quiet actually, and they roll forever. Very little rolling resistance for what they are. They shed water like crazy, and since they're so heavily siped they do well in the snow/ice too.
I think the Defender is warrantied to 60-70k miles depending on the tire size.
Old 02-12-19, 09:22 AM
situman
situman's Avatar
They are also heavy too! 40 something pounds each per Tirerack! I may go for the Premier LTX, but apparently they wear terribly.
Old 02-12-19, 09:48 AM
Madtiger
Madtiger's Avatar
It’s 38-39 lbs or so. Have you seen BFG KO2??!! They are like 51 lbs! . Defenders are lightweight compared to that!
Quick Reply: 265/65/18 tires
