P0125 p10171 p0174 p1130
I'm at my wits end. I've had this at the dealer for three days. I've replaced the intake gasket, plugs
, Mass air flow sensor and the engine temp sensor. Still getting these codes. The dealer likes taking my money and is still not sure. Any one know what to do? 2002 Lexus rx300. 129900 on the clock. Please help.
The fix is not a simple fix. I am not trying to disparage carguy's opinion, just saying at times it can be complex.
If it is a bad sensor ... swap takes care of it ...[most on the forum would like to see it that way].
If there is introduction of air in the closed loop .. things can become complicated as the ECU keeps compensating. At this time you really need a savvy tech, who in my mind needs to run an open loop test and take the readings from sensor and then diagnose potential source and then address it.
There is video on the net where a guy explains some of it one white board.
I guess it is time to ask the dealership to assign a master tech.
Salim
Salim
Yes
Along with the intake, plugs, vacuum checked, exhaust leak fixed and maf sensor changed
Well, they (mechanic, an able one) better start checking wiring or possibly a bad ECU.
Assuming they already checked the correct voltage outputs of the AF sensor.
It should stable at 3.3 V at idle.
During fuel enrichment, using a scan tool, there is a case that the output voltage of the A/F sensor is below 2.8 V
The other (working bank) should also be a reference on the change.
so i replaced the ebay denso o2 senosrs with ngk.As it was throwing the codes for that. it took care of everything for 1 day. i hit the gas hard and then the vsc light and check engine light is on. not it onlyhas a code for bank 2 lean. Any help here?
Atleast its the easy bank to replace.
Without looking at your fuel trims or AF voltage at idle, i cant say for sure what that LEAN code maybe. (P0171 im assuming).
Granted you dont have any exhaust leaks in that bank.
But usually when this code pops up, its more than likely a bad reading AF sensor.
Just for future reference:
O2 sensors are different that AF sensors.
O2 sensors are located after the cat.
AF sensors are located before the cat.
Those two words in the same sentence is concerning. Was it a reputable seller?
VSsc400
RX - 1st Gen (1999-2003)
12-28-04 07:57 AM
