1uz-fe bank 1 vs bank 2 coil pack difference???
Is there a difference in the 2 ignition coil packs on a 1995 1UZ-FE?
The part number for the individual packs are: Bank 1 = 19080-50011 Bank 2 = 19090-50011.
I ordered 2 coil packs from Rock Auto thinking both were identical, but after doing a little reading, some people are saying there is an internal resistance difference between the 2 coil packs...is this true...and would it really make a difference if I used the same part number for both coil banks???
Those two are electrically the same but the mechanically a bit different. As long as you can install it, either will work.
