2007 Lexus GS 350 with 300,000 Miles and Climbing - Part 1
By Edsel Cooper
You want your Lexus to be immortal? Forum Member mmade22 shows us the way.
By Edsel Cooper
I did this every oil change until I went through a full case of fluid. Last time I changed the fluid, it was as clean as it was going in.
To check fluid level once you fill it back up, there is a special sequence to bring up transmission temperature on the gauge display. You pull the fluid check bolt and fill it until it trickles out at the correct temp. If you replaced the fluid that came out, it should be very close. A little over full wont hurt anything.. and I do mean "A little".
I changed the wife's at 130k and it was black as coal but didn't smell burnt. The fluid retains all of the clutch material and such so don't panic if it looks nasty. From there on out after the full change, just change every 30k. Yeah.. the US manual says otherwise.. the manual in Japan states ~30k miles.
fuddyduddy
12-31-22 05:15 PM
plunger
GX - 1st Gen (2003-2009)
03-31-12 12:15 PM
