Door Panels finally replaced!
After a year & a half my door panels are finally replaced!
Took about 3 hours this morning, my only issue is that the wood grain doesn’t match.
I told the service advisor, but he said it was built to my vin & should be a match. He also said it could’ve probably changed color over the past 10+ years.
Total was $3,643.62, labor was only $170
What would you guys do about the mismatched wood?
EDIT:
I forgot to mention, this was done as "goodwill/warranty repair" I paid nothing out of pocket & was even given a loaner for the couple hours it took.
Before
After
This actually bugs me more than it should
EDIT:
Before
After
Former Sponsor
I believe that is real wood. So I guess there would be degradation over time, more so than a composite. Leading to a mismatch. That would seem to make some sense to me. Don't know what I would do about it. Maybe weight for the new to match the rest of it? There are somethings that would really irk me. I'm not sure that is one of them. Maybe … maybe not. Glad you got it done finally!
I could not live with that! Do you have the wood trim pieces from your old panels? Why not replace the new pieces with the old one? Or, find a company that could vinyl wrap to match. There are so many types of wrap these days that look identical to wood veneer.
The extent of the mismatch is literally unbelievable.
If you kept the old door panels (or can retrieve them pronto from the dealer), take a look at the backside to determine if it is possible/practical to swap panels.
I’m not so sure about degradation but the wood grain looks different, it is definitely not the same wood as the 10 years old original one and probably it cannot be....
I am going to talk to the manager again tomorrow. It bugs be how not only the color is off, but the pattern seem different as well, but I understand its hard to match something 10+ years old with just a vin #
What you're dealing with on the mismatch is different factory suppliers for the same part. They've either changed suppliers for the door panel, or the "sub" supplier for the wood has changed or doesn't have access to the same wood trim, etc... Any number of things could have changed in a decade. While the wood trim may fade due to UV light that difference is fairly significant, and I agree the grain doesn't match. Resolution will be hard because all the dealer can do is order the part number and you'll get what shows up. There's no telling which lot or supplier or even how old the part is because no one gets to choose which warehouse shelf it comes off. You'd have to do a deep dive on Lexus suppliers and lot numbers to try and track down info if it's even available.
I would go dumpster dive behind the dealer and get your old trim, haha.
Former Sponsor
Former Sponsor
Having worked as a design engineer for Toyota, I can say that is VERY unlikely. Toyota is very loyal to their vendors, and vice-versa. They push their vendors to make them and their products better. The vendors do get better. The vendors become more sought after because they have been driven to become better. And what the vendors like best … they get PAID by Toyota with no games. Unlike when I worked at Hyundai. The vendors were much less responsive because Hyundai did whatever they could to prevent paying a vendor. That's my experience with just a small segment of differences between the 2 companies.
the old panel looks fine..
Yeah it just looks dirty. The upper section of the door handle can get faded over time but I found a vendor on Ebay "Seats Restore" that make a perfect match leather paint/dye that restored the section of my door handle. It was a perfect match. I did my lower seat bolster also. Btw the color is "Light warm gray" Includes is a toothbrush shaped applicator which spreads the dye perfectly.
I would have the dealer order another set of panels to see if it will match better. When I did the 2008 GS350 brushed aluminum seat trim mod on my 2007 GS350, there was 1 out of 4 trip pieces was CLEARLY darker than the rest. I found myself always staring at the darker trim when I got into my car and could not live with the way it looked. I had the dealer order another batch. They claim that I needed a vin number which was BS. When the 2nd set came in it I was able to sort and match the final trim color perfectly.
