120 volt AC outlet not usefull
Old 08-21-18, 12:25 PM
joindy
joindy's Avatar
Default 120 volt AC outlet not usefull
I had thought I could use this outlet for small hand tools, small appliances etc. But, online info states can only handle 100 watts, which limits it to small radio, charging a phone etc. May not even be enough to power a laptop. Just wanted to verify my understanding of its limited use.
joindy is offline
Old 08-21-18, 12:59 PM
tecman
tecman's Avatar
Yes, only 100W. I tried to run a 18V Makita battery charger with no success, I use it for a 12V Makita battery charger.
tecman is offline
Old 08-21-18, 01:49 PM
Acrad
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
I mainly use it to charge another battery pack that can do 600-800 watts but can only draw 70 watts itself from it's AC charge adapter.
Acrad is offline
Old 08-21-18, 03:28 PM
Acrad
Acrad's Avatar
Not sure what gauge wire is used to the rear inverter but wonder if the 400W unit used in the 4R IIRC would work in the back. One would need to know if the wiring was up to it though. In FSM... just looks like a plug and play inverter module in the back.
Acrad is offline
Old 08-22-18, 06:40 AM
bd5400
bd5400's Avatar
Isn't the 400W available on the GX in other markets? I wouldn't be surprised if the unit is shared.
bd5400 is offline
Old 08-22-18, 07:11 AM
jkonquer
jkonquer's Avatar
Is that enough to power a small fridge? thinking about buying an Engel fridger.
jkonquer is offline
Old 08-22-18, 04:43 PM
Acrad
Acrad's Avatar
I'm not sure on other markets have the 400W. 4R models... not sure Gen/Years or current have something like this on dash
http://www.toyota-4runner.org/5th-ge...t-console.html
•• I'd be careful with refrig models in that jack because starting wattage for something like refrigerators can sometimes be 2-3x times running wattage. My ARB 55 quart draws about 50-70W when just running on AC adapter... granted it isn't running all the time.
Acrad is offline
jkonquer (08-23-18)
Old 08-22-18, 11:40 PM
erx808
erx808's Avatar
Lets get more wattage back there! Must be modded!!!
erx808 is offline
Old 08-23-18, 02:03 PM
Acrad
Acrad's Avatar
Looks like the 4R version that supports 100/400W goes into each mode depending on whether the vehicle is driving or in P/N. 400W is only available while in P/N but there is apparently some override one can do. Best bet would be to run a heavier gauge wire run to the back and install your inverter of choice. I like to use Sine wave models myself. One would need to open it up and see what they ran for this simple 100W unit. I am doubtful wire gauge is very heavy stock.
Not exactly cheap stock for what it is... new prices are $350-$900. You can purchase some capable inverters for that price.
Acrad is offline
Old 08-24-18, 11:05 AM
erx808
erx808's Avatar
Sounds like a way forward !
erx808 is offline
Old 08-26-18, 06:24 PM
Acrad
Acrad's Avatar
This 2012 media release for Canada does say rear outlet is 400W
http://media.lexus.ca/releases/the-2...thentic-221022
"120-volt/400-watt power outlet"
Old thread on topic
https://www.clublexus.com/forums/gx-...ac-type-b.html
Acrad is offline
Old 08-26-18, 06:32 PM
Acrad
Acrad's Avatar
This is absent from my 2012 owner's manual but present in 2010 & 2011 owner's manual
Acrad is offline
Northcut (12-27-20)
Old 08-26-18, 06:35 PM
Acrad
Acrad's Avatar
Might be a little too optimistic but do we have another crawl control switch scenario here... the inverter is capable of 400W but is missing the dashboard switch? :-) Need to see if there are multiple PN's for the inverter in cargo area.
Another old thread
https://www.clublexus.com/forums/gx-...-inverter.html
Acrad is offline
Old 08-26-18, 06:58 PM
Acrad
Acrad's Avatar
400W unit ---> 86210-60140
https://www.megazip.net/zapchasti-dl...340617-7340617
Acrad is offline
The following 3 users liked this post by Acrad:
bbqsoup (08-27-18), jkonquer (08-27-18), Otherone (08-27-18)
Old 08-26-18, 11:25 PM
erx808
erx808's Avatar
Default Seems progressive
I like it and going to pursue
erx808 is offline
Quick Reply: 120 volt AC outlet not usefull
