LS460 Detailed Problems and Solutions
July 2018. I'm starting this thread to chronicle my experience maintaining a new-to-me LS460. Clean title. 2007, 143000 miles. $4800. ABS, VSC, traction, and brake warning lights go on randomly sometimes all at once sometimes just one at a time.
It needs some minor attention including; mirrors (center rearview does not respond, driver side mirror does not fold), sometimes all or any combination of the 3 passenger windows do not work from the drivers control panel, the motor for the glove box went so its a bit annoying to open, the rubber seal of the sky roof glass panel is slightly ripped (does not leak, does not even produce wind noise on highway) so I do not open it.
Then some major work including; ABS pump +brake line bleed (the lines leak break fluid, for now I refill fluid every day), front 8 control arms +tires and alignment.
The unknown; The fuse for the center console keeps blowing. Random electronic components are intermittent. The day after I got the car it did not start, a couple times the car shorts out entirely all interior light and power steering goes out for a split second. Mechanic says the battery and alternator don't have high enough charge (electrical problems to be determined). Since those first 3 days though, I have not had any issues with the car since.
I have already ordered most of the parts for the major work and some for the minor work. I thank you, members of clublexus for helping me with that! I just need to figure out whats up with the electrical. The very small issues like the windows and mirrors and glovebox don't need to be fixed but will be in the future when I have time. Will post detailed and organized updates!
Added clean title to OP, thanks.
I got it on craigslist from an accountant, young guy only a few years older than me. He had it from 80k to 140k. He definitely took very good care of the car in its prime, but he has a large garage now many new cars so he let this one the oldest go. I am fairly sure he used it to speed recklessly down the highway cross country.
gmcbean (12-22-18)
Sounds like it's going to be a lot of headaches. Why did you choose to buy it knowing it had some of these problems?
Yes it is clean title.
On the trunk, I bought an 07 over the weekend and had the trunk issue until the dealer pointed out that a trunk engage switch was on (or off?) in the glove compartment and when that happens, the interior switch and buttons outside don't work. Feature so valets don't steal stuff in the trunk. You look into that?
Legus (07-18-18)
My close friend is a good mechanic and I know he can do all the work. I got all the major necessary parts for around $2500 and the car should be almost 100% by next month. In the end, its because the custom work that the car came with (all black everything, new f sport brakes, limo tints, exhaust) is worth more than the mechanical work I will put into it.
Update
My friend brought a voltage reader and the OBD scanner from his job a couple times over the past few days. As of today still battery and alternator read just slightly below normal. Low voltage code. No other codes, woo!!! Doesn't read any ABS or associated codes as long as the brake fluid is full, so those lights are definitely just the leak we expected. Will pass inspection tomorrow. He also found an oil leak, damn, hopefully in a simple enough spot. It will be in his shop all day tomorrow, once its on the lift we hope to see nothing but the front control arms needing replacement as expected. Electrical issues still to be decided.
Legus (07-19-18)
My mechanic will be checking thoroughly for the root of this problem while its in the shop.
