Anyone pulling transmission temps via OBD?
Old 04-20-18, 12:12 PM
Acrad
Acrad's Avatar
Received 3,562 Likes on 2,332 Posts
Lightbulb Anyone pulling transmission temps via OBD?
OBD Fusion/Link - monitor AT temps
Monitor status of torque converter lockup
I was looking into options on Android and IOS. I know what can be done with TS but this is for everyday and towing.
As mentioned before looking at OBD Fusion on IOS and Torque Pro on Android. I purchased the Toyota model year specific enhancement pack on Fusion but neither are showing any out of the box transmission gauges that actually read for me anyway.
I'm seeing some discussion about custom PIDs.
http://www.tundratalk.net/forums/tun...nny-temps.html
I'm just using an older Wifi based ELM327.
http://www.tundratalk.net/forums/743900-post33.html
I tried the first formula out but didn't seem to pull anything for me.
If anyone has luck with these let me know. I'll probably play around with it more later this weekend.
For sensor 1 (Pan Temp):
OBD2 Mode and PID: 2182
Long Name: Transmission Fluid Temperature 1
Short Name: Trans 1
Minimum Value: 0.0
Maximum value: 300.0
Scale factor: x1
Unit Type: °F
Equation: ((((A*256)+B) * (7/100) – 400)/10)
OBD Header to use: left blank
For sensor 2 (Converter outlet temp):
Long Name: Transmission Fluid Temperature 2
Short Name: Trans 2
Minimum Value: 0.0
Scale factor: x1
Unit Type: °F
Equation: ((((C*256)+D) * (7/100) – 400)/10)
Old 04-20-18, 12:18 PM
Trijicon
Trijicon's Avatar
I'd be interested in this as well since I tow often. Do you have or thinking of an auxiliary trans cooler as well?
Old 04-20-18, 12:21 PM
Acrad
Acrad's Avatar
I don't currently have one but have thought about it. There is an OEM PN I came across at some point since it is an option on the Canadian Executive model.
Old 04-20-18, 12:22 PM
Acrad
Acrad's Avatar
I notice Koan has a bracket that uses existing holes to mount the cooler. The two existing for the horns.
https://www.kaon.com.au/store/p5/Pra...ooler_Kit.html
Old 04-20-18, 12:37 PM
Acrad
Acrad's Avatar
http://www.tundratalk.net/forums/tun...mperature.html
Might be this one too for the convert temp using PID 21d9
((((G*256)+H)*(7/100)-400)/10)
Old 04-20-18, 01:48 PM
Acrad
Acrad's Avatar
That first code does work in original post. Will test out TC one.
Old 04-20-18, 01:52 PM
bbqsoup
bbqsoup's Avatar
Using ODB Fusion and the Extra Package for Toyota, I was able to read via the Wifi OBD. There are actually A/T oil temp 1 and A/T oil temp 2 and they are a few degree different from each other.
Old 04-20-18, 01:59 PM
Acrad
Acrad's Avatar
Getting different numbers for pan, coolant and tc
this is with torque ... need to test with fusion
Old 04-20-18, 03:52 PM
bbqsoup
bbqsoup's Avatar
I tried this in ODB Fusion and it said No Data was received. Looking through the Toyota Extras, I don't see one for TC either. The Extras looks like what showed in Techstream so if Techstream has temp sensor value for TC, then it should have it too. However I don't recall I see TC in Techstream. Can you confirm?
Acrad (04-20-18)
Old 04-20-18, 04:10 PM
bbqsoup
bbqsoup's Avatar
I found this on tundratalk.
"FWIW, the A/T oil temp 1 is the pan, 2 is the torque converter. "
Temp 2 (TC) is usually higher when it's locked and both are similar at crusing speed (unlocked).
The following 2 users liked this post by bbqsoup:
Acrad (04-20-18), breed (11-06-20)
Old 04-20-18, 04:38 PM
Acrad
Acrad's Avatar
I'll play around with it this weekend with Fusion. It was nice... I just got done pulling a small trailer with cargo that weighed around 2800lbs.
Transmission temps stayed with 10-15 degrees of coolant.
Hottest I saw was around 228 degrees. Normal running temps are usually within 5 degrees of coolant which is usually 205-210 degrees.
Old 04-20-18, 04:39 PM
Acrad
Acrad's Avatar
I will say this.. if pulling a trailer on a grade put it in 4th gear. You can watch it drop down in temp.
AznRacer (02-17-22)
Old 04-20-18, 06:03 PM
Acrad
Acrad's Avatar
If we reach a dead end on Fusion I'll open a support ticket to see if they can implement something based on what Torque can do.
Old 04-20-18, 06:20 PM
bbqsoup
bbqsoup's Avatar
Looks like the Toyota AT temp 1 is for the transmission temp at the pan and AT Temp 2 is for the torque converter. I added both and the oil temp
too. They are very closely match at cruising speed.
Acrad (04-20-18)
Old 04-20-18, 06:49 PM
Acrad
Acrad's Avatar
Seeing you have it working on Fusion.
I need to compare my coolant temps between the two apps. Mine are running about 10 degrees higher at cruising on Torque compared to yours. It could be related to towing a trailer though. I noticed a few degrees difference at almost all times between my AT Temp 1 & 2 with Torque.
Quick Reply: Anyone pulling transmission temps via OBD?
