NX - 1st Gen (2015-2021)
Samsung S9 contacts not syncing
Old 04-13-18, 06:44 AM
Jz69
Jz69's Avatar
Default Samsung S9 contacts not syncing
When i connect my new Samsung S9 to my Lexus is350 (2015) the contacts do not load
Old 04-13-18, 07:30 AM
LOLjasonW
LOLjasonW's Avatar
Go into the setup in the car, then into the bluetooth settings and go into the contact/call history. Click update contacts. When you do this go into your phone and go into your contacts. At the top of your contacts there should be the 3 dots at the top right corner next to the search bar, tap that, and then tap share. Select all contacts you want to share with car (there is a select all tab), then tap share again. A little box should pop up with connection options. Tap bluetooth, it will then bring you to the bluetooth screen and you can select the device or vehicle you want to share the contacts with.
Usually hitting update contacts will initialize it, if not this is the LONG way to do it
Old 04-22-18, 07:03 PM
Jz69
Jz69's Avatar
Thanks LOLJasonW. Tried all that with no luck. I think it may be the security settings imposed through work. Still confusing though, as the previous phone had no problem.
supra725
12-19-16 01:37 PM
BrandonYas
03-18-14 06:58 PM
Adamjeeps
05-17-12 07:42 AM
Yaff
03-13-12 09:57 AM
OutCaster
02-15-08 05:50 PM
Quick Reply: Samsung S9 contacts not syncing
