Need picture of dashboard circuit board
Old 02-21-18, 10:34 AM
Jpeggman
Jpeggman's Avatar
Default Need picture of dashboard circuit board
I’ve used the excellent information in this forum a few times in the past to keep my ‘94 LS400 running, and now have a new problem with the dashboard display. I thought that maybe one of the capacitors I replaced about 10 years ago had failed, but this is a different one. C106 I think it says. It leaked and caused a small short which burned a little bit of the BACK of the large circuit board of the dash assembly. I need a picture of the back of that circuit board so I can try to reconnect a couple of lines around that capacitor.
Does anyone have a picture available, or can you guide me to someplace I can get a picture of that circuit board back side?
thank you!
Old 02-21-18, 10:57 AM
YODAONE
YODAONE's Avatar
thank you!
If in budget,, probably easier to obtain an extra cluster so you have the board immediately available to you...or should you require replacement.
Old 02-21-18, 11:31 AM
Jpeggman
Jpeggman's Avatar
Yes, I could do that, but am getting ready to offload the car and want to have it in the best shape for the least amount, so if I can fix what I have, that would be ideal. I’m just hoping to find someone somewhere who has a picture available. If I can’t fix it, then I’ll deal with it as you suggested.
Old 02-23-18, 05:58 AM
billydpowe
billydpowe's Avatar
one of these might help:
http://www.arfc.org/complaints/1994/...m/problem.aspx
Attached Thumbnails Need picture of dashboard circuit board-91_instrument2_92d1d948c7a621c7dd51a88f3634fa52511b786b.jpg   Need picture of dashboard circuit board-327574d1399404783-1996-nakamichi-stereo-wiring-diagram-2000-ls400-nakamichi-audio-system-diagram.jpg   Need picture of dashboard circuit board-graphic.jpg
Old 02-27-18, 09:54 AM
Jpeggman
Jpeggman's Avatar
Thanks billydpowe- I wish those could have helped but none of them shows the circuits I need. There’s GOT to be someone out there with pictures of this circuit board...I just have to hope that one of them sees this thread!
Old 03-01-18, 09:18 AM
billydpowe
billydpowe's Avatar
I could not bring anything up.. my only book is 98-2000
Old 03-01-18, 09:28 AM
billydpowe
billydpowe's Avatar
check this: http://www.faxonautoliterature.com/1...al-P18900.aspx
Old 03-01-18, 09:31 AM
Jpeggman
Jpeggman's Avatar
Ok, no sweat. I ordered a replacement dash on eBay and will post all pics here just in case somebody else needs them in the future.
ZoomTroop
04-26-18 05:03 AM
Jpeggman
02-19-18 09:34 PM
btz0
09-05-13 09:14 PM
jrm7885
04-14-09 12:53 AM
mmccutchin
17
03-11-06 11:46 AM
Quick Reply: Need picture of dashboard circuit board
