Car Wont Start Unless I Disconnect and connect battery again
Old 02-18-18, 05:09 PM
Yabito
Yabito's Avatar
Default Car Wont Start Unless I Disconnect and connect battery again
Hey, I will like some help, I left the car all good is been a while the car was off like 6 months, I always leave the car with the battery disconnected, when I recently got back so I took the cover of the car, open the hood and do the process I always do to turn the car safely after long period without been on, but this time, the first thing is that the car won't change gears break the car try to put R but the safe is not loosing so I do it manually using the releaser, and car after done with the manual releaser I can go to all the gears fine R, N, D no problem if I put the car back to P and again to R is all good, now here comes the issue when I turn off the car and wait like a min, and try to turn on the car again the car turn on and instantly off (and btw as soon as I turn off the car the P won't release the gear) so if I disconnect the battery from the car like for 10 sec and connect the battery again and start the engine car start just fine, again try to put any Gear and the car won't release the gear I have to do it manually pushing the button down that u use to put a gear when the car is off, button line thats one thing but most annoying is the car won't start after is been turn off unless I disconnect and connect the battery again, need some help.
Old 02-19-18, 03:23 PM
MedicalDoc
MedicalDoc's Avatar
Which terminal r u disconnecting?
Old 02-20-18, 06:30 AM
Yabito
Yabito's Avatar
really does not matter the terminal, but I got to the problem, car also was detonating at 4xrpm so it was deff electrical issue, so I check the ECU and found that there was the problem, and for me that a big a#$% problem, since I have a Tom's but I took it to a electrical friend and hopefully he can resolve the fail jumpers.
Old 02-20-18, 05:48 PM
burteboy
burteboy's Avatar
Check your stop light fuse
Old 02-20-18, 07:08 PM
Yabito
Yabito's Avatar
mine are the led tail lights, and have to light in the dash, and is all good already checked, I got to issue already, the console has a little black plastic thing inside that is like the actuator, have one leg broken so thats that
NYKnick101
06-07-16 07:32 PM
Farbound
Performance & Maintenance
05-14-14 09:30 PM
Gee2anIS
IS F (2008-2014)
13
05-01-14 07:14 PM
johnnunez2
10-26-11 04:25 AM
Quick Reply: Car Wont Start Unless I Disconnect and connect battery again
