ECU Tune for ISF
Old 01-16-18, 10:03 AM
Stingraygt
Stingraygt's Avatar
Default ECU Tune for ISF
Has anyone used the RR racing OBD device tune for Lexus IS-F ECU? And has anyone toggled back and forth between factory settings and the tune? Let me know your experience.
Thanks
Old 01-16-18, 11:10 AM
Diesel350
Diesel350's Avatar
Also I would like to know if heatsoak affects the ECU Tune. Will you lose power with excessive heatsoak on the tune?
Old 01-16-18, 11:17 AM
dlee74
dlee74's Avatar
Thanks
I haven't toggled back and forth between the stock and tuned ECU settings. Just installed the tuned ECU settings. LMK if you have any question in regards to uploading the tune. Pretty straight forward instructions from RRRacing.
Old 01-16-18, 11:32 AM
liquidtek
liquidtek's Avatar
What's the reasoning between switching from tune to factory and back? If it's just for servicing at the dealer there's no point they won't know. Most of us don't have the luxury of being able to go back to stock without doing some other supporting mods since we have headers/tuned intake ect. I've flashed from stock>TTFS>RR tune and different tunes in between without issue.
heatsoak is heatsoak. its going to affect the car tune or not.
Old 01-16-18, 11:40 AM
dlee74
dlee74's Avatar
Just curious. Which tune did you find better in performance? TTFS or RRacing? I am really enjoying the RRracing tune. I agree too that the dealer most likely won't know if the ECU settings were changed.
Old 01-16-18, 01:11 PM
liquidtek
liquidtek's Avatar
I've posted quite a bit of stuff with the tunes previously if you wanna dig thru the searches. TTFS is pretty much non existent in the Lexus community now so that should be good indicator which was more successful.
dlee74 (01-16-18)
Old 01-16-18, 02:01 PM
semnosNSX
semnosNSX's Avatar
If you have the RR-racing tuned intake system, you can't go back to the OEM tune unless you remove the entire intake system and reinstall the OEM one...which can be a small pain in the a$$.
Old 01-17-18, 05:49 AM
ninten5
ninten5's Avatar
Wait...wait there is an OBII ECU tune? So I can apply the tune remotely? How much and where can I get it? ALso, does it has the 7200rpm redline?
Old 01-17-18, 05:58 AM
Stingraygt
Stingraygt's Avatar
http://www.rr-racing.com/RR-Racing-T...isfitk0003.htm
The following 2 users liked this post by Stingraygt:
graphX250 (01-19-18), ninten5 (01-19-18)
Old 01-17-18, 07:55 AM
dlee74
dlee74's Avatar
Here is another link I used to get the OBD device and installed it remotely. It does redline at 7200 rpm. It is pretty straight forward.
http://www.rr-racing.com/RR-Racing-L...isftune002.htm
ninten5 (01-19-18)
Old 01-17-18, 11:36 AM
Leander311
Leander311's Avatar
RR Racing's tune is great. The 7200/7400 rpm redline options do not fix an issue where the stock torque converter unlocks beyond stock redline, but they'll fix that if you mail in your ECU to them, which they can turn around in 1 business day for you.
As has been said, heat soak is heat soak. Being one of the most technologically-advanced mainstream production V8's in history, even the stock tune is sensitive to heat, and on CoTA last summer, I noticed this in RR Racing's tune as well. She feels much stronger in colder weather. For the same reason, a 45MW power turbine I help manage makes much more power when IAT's are low. It's simple physics.
Old 01-17-18, 12:23 PM
sc3dreamin
sc3dreamin's Avatar
I emailed them and they told me even if I mail the ECU it will still unlock past 6800 rpm
Old 01-19-18, 06:42 AM
ninten5
ninten5's Avatar
That's cool! But what is this torque converter unlocking mean? I know the F has the power up top and would love to extract more of it.
Helo58
IS F (2008-2014)
12
01-28-16 01:52 PM
MRxSLAYx
IS F (2008-2014)
49
09-17-14 07:26 PM
Nigel-JDMParts
IS F (2008-2014)
262
05-24-14 02:53 PM
Nigel-JDMParts
IS F (2008-2014)
121
05-10-14 04:47 AM
MjThind
IS F (2008-2014)
30
07-16-12 03:49 PM
Quick Reply: ECU Tune for ISF
