headlights on for 30" closing doors
Hello, in my SC430 of 2002 (USA) when I open or close the doors, the headlights lights on for 30 ", how can I change (or reset) this time? Thank you. Costa.
Thanks Bgw70, maybe I expressed myself badly ... (my mother language is not English), I would like to eliminate this timing ... or reduce the 30 " to 0".
these two links will show you what you need...the second link has a list items you can change on your car.
https://www.clublexus.com/forums/sc4...r-2-0-4-a.html
https://www.clublexus.com/forums/sc4...-function.html
You can try hitting the lock button on your remote twice. Once to lock the doors and once to turn off the lights. I don't know if it works, but you can try it
Hi DashingDar, grazie per il suggerimento ... lo avevo già provato, ma senza successo. La mia SC è un modello del 2002 per questa ragione forse non funziona. Ho anche scoperto che le luci si accendono per 30" sia allo spegnimento dell'ignition e dopo anche al blocco delle porte ... due volte consecutive ! Ma se apro la porta prima estrarre la chiave questa prima accensione non avviene. Ora, proverò ad intervenire, da solo, sul SETUP, e per far questo ho acquistato on line, il "Tech Stream Software Cable V. 2.0.4 - MINI VCI J2534 OBDII" compatibile con il mio laptop con S.O. WIN 8 -x64.
Lo riceverò dalla China fra circa 1 mese, e mi costa circa 35 € (io vivo in Rome - Italy ...). Ciao. e ancora mille grazie per il suggerimento. Costa.
sorry ...
Hi DashingDar, thanksa lot for your suggestion ... I had already tried it, but without success. My SC is a model of 2002 for this reason maybe it does not work. I also discovered that the lights turn on for 30 " both at the turning off of the ignition and also after the locking of the doors ... twice consecutively ! But if I open the door before I remove the key this first ignition does not happen. Now I'll try to change the SETUP, and to do this I bought online, the "Tech Stream Software Cable V. 2.0.4 - MINI VCI J2534 OBDII" compatible with my laptop with SO WIN 8 - x64.
I will receive it from China in about 1 month, for about 35 € (I live in Rome - Italy ...). Hello. and a thousand thanks again for the suggestion. Costa.
Johnhav430
02-12-17 04:23 PM
strife
03-15-09 02:17 PM
