Red Triangle>>
Old 09-22-17, 04:59 PM
jimisbell
jimisbell's Avatar
Default Red Triangle>>
It came on today, wasnt the tires because it didnt say so. It says Maintenance Required....what ever that means????
Old 09-22-17, 05:25 PM
yardie876
yardie876's Avatar
It means maintenance required... lol. It is a scheduled reminder that comes on after a preset amount of miles driven to remind you to take it in for scheduled service at the dealer.
Old 09-22-17, 05:40 PM
jimisbell
jimisbell's Avatar
OK, so probably the dealer set it when he changed the oil. And, its miles, not time??
Old 09-22-17, 06:05 PM
yardie876
yardie876's Avatar
Yes I believe the dealership sets it. Nothing to worry about. If you’re due for service, it’s time to make that appointment soon.
Old 09-22-17, 06:24 PM
jimisbell
jimisbell's Avatar
well, I dont intend to change oil at 3K miles........unless he used really cheap oil.........
Old 09-22-17, 07:05 PM
rkw77080
rkw77080's Avatar
The red triangle is programmed to come on with "Maint Reqd Soon" every 4,500 miles (and again with "Maint Reqd" at 5,000 miles) to remind you to change your engine oil.
You can reset the warning light (you don't necessarily have to change your oil every 5,000 miles) by the following procedure:
1) With the ignition "ON" push the trip meter button on the dash-board repeatedly until you have a blank display (for example, neither A nor B trip mileage is displayed).
2) Turn ignition "OFF", and while pressing and holding the trip meter "RESET" button on the dash-board, turn the ignition "ON"
3) Keep pressing and holding the "RESET" button until the "Mileage Reset" appears on the display and a warning tone sounds.
Jabberwock (09-23-17)
Old 09-22-17, 07:06 PM
yardie876
yardie876's Avatar
Check out post #7 from this thread on how to reset the light. You’ll just have to track your maintenance schedule yourself.
https://www.clublexus.com/forums/ls-...ing-light.html
Old 09-24-17, 06:53 AM
jayclapp
jayclapp's Avatar
You can go into the schedule menu and set each and every item you want to be warned by date or mileage. When to change battery, filters, tires, wiper blades, steering fluid, etc, even allowing you to name and use a couple of buttons for whatever you want.
Old 09-25-17, 05:03 PM
jimisbell
jimisbell's Avatar
Where is the "schedule menu"?
Old 09-25-17, 07:14 PM
rkw77080
rkw77080's Avatar
Old 09-26-17, 02:24 PM
jimisbell
jimisbell's Avatar
Found it. Thanks.Also reset the red triangle and that works also. Now to see if the tire reset will last for more than a month.
heidihidin
Maintenance
10-13-18 11:55 PM
aztr0
NX - 1st Gen (2015-2021)
01-22-17 05:32 PM
Orbit
RX - 3rd Gen (2010-2015)
30
12-29-10 04:08 AM
2thfixr
10-20-06 09:28 AM
afedelecpd
GX - 1st Gen (2003-2009)
16
06-09-06 07:16 AM
Quick Reply: Red Triangle>>
