Wheel rub issue after camber arms?
I have a 2015 IS350 F-Sport AWD.
- Lowered on RS*R Down springs
- Velgen VMB5 Wheels
- 19x9 front / +35 Offset 235/35/19
- 19x10.5 rear / +45 Offset 265/30/19
I am experiencing inside tire wear in the rear, and I plan on purchasing the SPC Camber Arms. Will adjusting the camber closer to stock increase my risk with rubbing? So far, I haven't had any issues with rubbing. Roads here get fairly bumpy too
There are few other forums on this topic. so please search.
With that said, camber arm should help a little with wear but it won't get rid of the inner wear since it is a toe issue.
sounds like you are one of those
take a look at this thread and chime in, you guys have a mystery to solve together
https://www.clublexus.com/forums/sus...tire-wear.html
that's a good idea, if your first alignment was done right after lowering the car, the springs may have settled over time causing the toe to have changed enough to eat your tires up.
As said your camber is less likely to be an issue. If you're experiencing excessive inner tire wear, the first thing you want to try (assuming you have respectable camber no more negative than -2 to -2.5) is 0 out your toe.
camber + toe eats tires. not just camber.
If you slammed your car without doing an alignment, then you're probably toed in and need to toe back out with an alignment.
Even for me, if i have a choice, I toe in on purpose for stability. I don't care if it causes excessive wear. Cause this is how BMWs are set up from the factory and i've learned with a performance sedan, tire wear is just something you live with. Besides i don't want my tires to last too long anyway. dry hard tires is bad.
didn't you say it was due to incorrectly installing the springs? something to do with the bushings?
If it is a inner tire wear than he has a toe out or negative toe issue, but most people with lowered IS' have toe in on their alignment.
Sorry for neglecting this thread for a few days... I am dropping the vehicle off at the dealership for an alignment in an hour and a half. I will see if they can give me the before and after alignment numbers and report back..
I'm about to grab a picture of the rear wheels as well how they're sitting right now.
that looks normal for our setups. if you want it to look like that, or have the same wheels, or have the same size wheels, you're likely going to rub if you align the (rear) tires to 0 which isn't possible with your setup, but may be with spc camber arms.
please do! my car is having similar issues with a lot of negative camber but I don't want to ruin the look of the car by raising it (I have RS*R coilovers). I think adding in camber arms will solve one problem but create another (rubbing along the fender liner) and raising the height of the car (specifically for me). there is also the problem with toe. ugh, what have I gotten myself into!?!
