What kind of wheels do I have?
Old 04-29-17, 01:13 PM
tony247
tony247's Avatar
Default What kind of wheels do I have?
Hi everyone. I just bought my new car this morning I'm not a huge fan of these 20" wheels and plan to sell/trade for the stock gunmetal 19s.
How do I find out the exact type of these wheels? I need to price them accordingly on craigslist. I believe these come in forged and cast iron, I'm not sure how to tell the difference- thank you and I appreciate your help!
tony247 is offline
Old 04-29-17, 01:26 PM
bagwell
bagwell's Avatar
http://www.cecwheels.com/collection/c882
bagwell is offline
Old 04-29-17, 01:42 PM
tony247
tony247's Avatar
Originally Posted by bagwell
youre a good man, thank you.
tony247 is offline
Old 04-29-17, 01:43 PM
Johnhav430
Johnhav430's Avatar
I prefer an OEM look myself, but have to admit, those rims look pretty nice. What size is the rubber? Are they staggered? If it were me I'd probably cruise around on those for a while to see how they behave...
p.s. the only thing about huge rims is they make the rotors look small, but isn't that an F Sport? So the brakes are pretty big I think...
Johnhav430 is offline
Old 04-29-17, 01:47 PM
tony247
tony247's Avatar
lol I hear ya, thank you. The rubbers are 245/35/20 front and 275/30/20 rear. They are nice for sure, but for me, I like it a little simpler so am looking for the oem 19s :
tony247 is offline
Old 04-29-17, 01:50 PM
tony247
tony247's Avatar
Bagwell, there's the regular c882 and then the c882 Forged. Any idea how to tell them apart?
tony247 is offline
Old 04-29-17, 03:43 PM
bagwell
bagwell's Avatar
No idea, but you can probably take 1 wheel off and look for info - or contact the manufacturer.
bagwell is offline
Old 04-29-17, 03:46 PM
tony247
tony247's Avatar
Got it, good idea. Thanks for your reply.
tony247 is offline
tony247
tony247's Avatar
BTW, silly question here, but what annotation tool did you use for the green arrow? I've been searching for one and I assumed you did that quite quickly lol thanks.
tony247 is offline
Old 04-29-17, 04:50 PM
mmarshall's Avatar
Congratulations on your purchase.
First of all, alloy wheels don't use cast iron.....it would be too heavy. By definition, they use an alloy (a mix of two or more metals, usually with aluminum as the primary base). Even the majority of engine blocks don't use cast iron any more. Forged-aluminum wheels usually cost more than cast-aluminum ones, because of their more expensive production techniques and greater strength.
I'm not sure just what your question or intention is. Did you buy the car with these 20" aftermarket wheels, and now want to sell them on Craigslist and replace them with 19" wheels? That's what it appears to be.
Whatever wheels and tires you end up with, make sure that the outside rolling-diameter of he tire is the same (or close to) what it was stock, because on modern cars, a number of different functions of the car's engine/transmission computer, speedometer, odometer, tire-pressure, anti-lock brakes, etc.... function on how sensors determine wheel-rotation speeds. Larger-than-stock wheels/tires can lead to slower wheel rotations, and your speedometer and odometer both reading low, which could make it easier to get speeding tickets, and possibly void the car's warranty, if the warranty is still applicable.
(All else equal), tire-profiles that low will give you a harsh ride, less traction on slippery roads, and more chance of tire/wheel damage from pothole or sharp-bump impacts. But it will quicken up the steering response on dry roads and make the car more responsive.
mmarshall is offline
Old 04-29-17, 05:29 PM
ragingf80
ragingf80's Avatar
Did they not publish the weight? I bet these are pigs. All show no go? I'd swap them as well. Congrats on the new car OP!
ragingf80 is offline
Old 04-29-17, 05:39 PM
Sulu
Sulu's Avatar
Came in cast iron?!? Those wheels must have been heavier than the car!
Sulu is offline
Old 04-30-17, 07:47 AM
tony247
tony247's Avatar
Thank you for your tips! Yes, I am wanting to replace them with stock 19" wheels. The ride is not as comfortable as others I've experienced so going back to stock wheels will happen. Do you think taking off the 20s and putting on 19s without additional modifications be ok?
tony247 is offline
Old 04-30-17, 07:48 AM
tony247
tony247's Avatar
lol, thank you. I bought this car from a non-lexus dealer so not much details were given on the car.
tony247 is offline
Old 04-30-17, 06:25 PM
mmarshall's Avatar
If the outside (rolling) diameter of the entire wheel/tire assembly is at or close to stock, there is enough air going through the wheel-spokes for brake-cooling, and the tires fit and turn in the wheel-wells without clearance problems or rubbing, then you probably shouldn't have any problems. I'd avoid Chinese-made aftermarket wheels, though, as I've heard (admittedly, without personal experience), that their quality and durability is not to the standard of many others.
Quick Reply: What kind of wheels do I have?
