Tranmission Mount Bolts
Old 04-23-17, 09:49 AM
takoberu
takoberu's Avatar
Default Tranmission Mount Bolts
Hello Club Lexus members. This is my first post after lurking the forums for quite a while.
Yesterday I was replacing my transmission mount, and I botched the job by breaking the head off one the bolts that connects the mount to the transmission. Could anyone confirm if the part # for the transmission mount bolts are 90119-08770?
Old 04-23-17, 12:18 PM
Banshee365
Banshee365's Avatar
All of the bolts for the mount are pretty low torque. It sounds like you are really trying to wrench them on there. Even the 17mm head bolts into the body are like 19 ft/lb at the most. I'm not near my computer so I can't confirm the p/n and torque specs just yet.
8055y (04-24-17)
Old 04-23-17, 12:34 PM
takoberu
takoberu's Avatar
Thanks. I think I damaged the bolts because my ratchet socket had a thick wall so it was tough ratcheting them in and out.
The problem I have now is I need to get new bolts for the transmission mount, but I do not know what type of bolt I need. I was planning on ordering it through the lexus parts site and was wondering what the correct part number is.
Old 04-23-17, 01:19 PM
VolumeToo
VolumeToo's Avatar
Exactly the same thing happened to me a few years ago, trying to remove one of the four bolts. I was annoyed and upset, but ultimately I left it as it was. After all, I figured it couldn't go anywhere...
Old 04-23-17, 06:14 PM
Banshee365
Banshee365's Avatar
The 4 bolts holding the trans mount to the trans tail housing are indeed 90119-08770 (10 ft/lb)
The 4 nuts holding the crossmember to the mount are 94150-80841 (10 ft/lb)
The 4 larger bolts holding the crossmember to the body are 90119-10551 (19 ft/lb)
Find a car in a junk yard near you and rob the bolts from there if you can. But the bolts will be cheap from the dealer anyway.
The following 3 users liked this post by Banshee365:
mpmp (05-02-17), UNCNOR (04-23-17), USDM (04-23-17)
Old 03-24-19, 10:30 PM
Sherl
Sherl's Avatar
How did you take off the stuck bolt. I am in the same situation now
Old 03-25-19, 06:12 AM
jaaa
jaaa's Avatar
Put car on jack stands, support transmission with another jack, take off bracket to get to whatever leftover shank is left of the bolt head you broke off, grab leftover shank with vice grip and remove.
Old 03-25-19, 07:11 AM
Sherl
Sherl's Avatar
Mine broke midway. Any idea?
Old 03-25-19, 08:04 AM
billydpowe
billydpowe's Avatar
Default See harbor freight bolt extractor
make life easy for 20 bucks
Old 03-25-19, 08:20 AM
Sherl
Sherl's Avatar
Thanks billy do you think I can still drive the car with one broken bolt?
Old 03-25-19, 08:30 AM
billydpowe
billydpowe's Avatar
sure, since I dont believe you have put a super charger on it, you should be fine.
I just used the extractors in my shop for several years and knew they were around..
Old 03-25-19, 08:53 AM
Sherl
Sherl's Avatar
Old 03-25-19, 08:54 AM
Sherl
Sherl's Avatar
Can you see the depth it has broken into? I am sure Lexus of Mission Viejo screwed it but using impact and damaging the threads.
Old 03-25-19, 12:57 PM
billydpowe
billydpowe's Avatar
yes I see, I would not worry about anything, if anything, these cars (thru 2000) are made better than any other (even Rolls)
File Type: doc
Old 03-25-19, 01:17 PM
Sherl
Sherl's Avatar
Absolutely. I have no questions. I already poured $1000s in restoring all the parts I know of. So for removing this seems I don't have a method than drilling and tapping them.
Quick Reply: Tranmission Mount Bolts
