Preferred Wheel Cleaner for GS350 F-Sport Rim
Old 04-21-17, 12:32 PM
imdlink
imdlink's Avatar
Default Preferred Wheel Cleaner for GS350 F-Sport Rim
I just wanted to get an idea of what you use to clean the rims on these vehicles. There are quite a bit of products on the market, so I just wanted to see what you all recommend. I just got in from the car wash and noticed some brake dust on certain areas of the rims that seemed to be harder than usual to remove.
Old 04-21-17, 05:25 PM
Dallasguy1
Dallasguy1's Avatar
I use diluted simply green, been using it in my past cars no problems so far.
Old 04-21-17, 08:04 PM
97-SC300
97-SC300's Avatar
Iron X is the best product to clean wheels safely. Once they are completely cleaned off from stubborn brake dust, proceed with weekly or biweekly washes and use normal car wash soap on the wheels.
Brake dust only gets bad once you start to neglect normal maintenance.
Old 04-24-17, 05:54 AM
2URGSE
2URGSE's Avatar
PoorBoy's Ph balanced wheel cleaner. I also use the speciality teflon brushes from Autogeek.net
It wouldn't be a bad idea to get the wheels off the car and clean them by hand and then seal them.
Old 04-25-17, 11:09 PM
XSV
XSV's Avatar
I have Iron X but haven't used it yet. Sonax is the best wheel cleaner I've used so far, but it's so damn expensive.
Old 04-26-17, 08:21 AM
Zelfiris
Zelfiris's Avatar
If you're washing your wheels regular, any car soap will do the job.
If brake dust is caked on over time, Sonax does an amazing job.
Old 05-03-17, 09:28 PM
lexiboi
lexiboi's Avatar
Anyone here used Chemical Guy's wheel cleaner products? If so, pros and cons please and thank you
Old 05-04-17, 06:08 AM
atoyota
atoyota's Avatar
I use a fair amount of Chemical Guys stuff, but I don't have any of their tire/wheel cleaning products. I like them, but I don't know or think they are superior to any of the other good quality detailing products. If you find a brand or individual product you like and gives you the results you want - go for it.
Old 05-04-17, 10:10 AM
lexiboi
lexiboi's Avatar
Yeah I was browsing through their website and was tempted to try their wheel cleaner out. I've always loved Sonax but they are just too pricey. But I guess it gets the job done.
Old 05-04-17, 01:15 PM
atoyota
atoyota's Avatar
For what its worth I use an all purpose cleaner, Optimum Powerclean, that you can dilute to different strengths for different purposes. That saves on buying a bunch of individual products like Chemical Guys and others would have you do.
Engine and jambs 1:1,
Wheels-tires-wells 3:1,
Presoak 5:1,
Interior surfaces 10:1,
Carpet TLC and light stains 20:1
Old 05-05-17, 06:27 AM
zmcgovern4
Auto Detailing Master
zmcgovern4's Avatar
My F creates some pretty serious brake dust... but I still don't need a dedicated wheel cleaner to make the wheels look like new again. Soap and water, or even just a rinseless wash is all I need. Routine maintenance is key.
Old 05-05-17, 07:26 AM
Blkexcoupe
Blkexcoupe's Avatar
I've used CG diablo wheel cleaner. It works, but their sprayers suck and the product doesn't stick to the rims as nicely as P21s Gel or sonax.
If you use that much sonax wheel cleaner, then start buying it in larger quantities and keep the small spray bottles to refill.
lexusplz
17
03-18-16 05:12 AM
smehta
13
06-05-11 07:40 AM
dsg03svt
IS F (2008-2014)
34
04-07-11 07:20 AM
SmokeyMav
03-17-09 08:54 AM
lexusk8
09-07-02 01:59 AM
Quick Reply: Preferred Wheel Cleaner for GS350 F-Sport Rim
