Borla drone eliminated in 20 minutes for 20 bucks
I bought these off Amazon 12 weeks ago and they finally arrived from China:
They are small enough that you can sneak them in there, no need to remove the bumper or tips or anything. Just needed to drill a small hole in the outlet of the borla for the mounting screw.
They can be removed in less than a minute per side. The drone is completely GONE. The loud bass droning of the exhaust is gone, but the sound is still almost the same as it was before.
Highly recommend giving this a try. Since I daily drive my car, I plan on keeping these installed during the winter months. But first impressions are so good, I may leave these in full time
https://www.amazon.com/Motorcycle-Exhaust-Muffler-Silencer-Diameter/dp/B00VG90W7K/ref=sr_1_3?ie=UTF8&qid=1485811668&sr=8-3&keywords=uxcell+motorcycle+silencer
can u share if you experience any power loss? it looks kinda restricting
also, can you clarify if you install these in 2 of the 4 outlets? or all 4 outlets? in order to quiet down the drone
I took it for a highway pull, and engine power seems healthy still, but its hard to tell for sure, since its winter, its cold, and I'm driving on 225 wide winter tires.
Put these in the lowers only. 2 out of 4.
Interesting a motorcycle exhaust silencer?? Well **** if it works
Like msgs350 said above^^^^^do you have headers as well as the Borla?
I can't see why these wouldn't quiet down header equipped cars.. These things are just essentially plugging off one of the two outlets per side... Which I'm sure causes some exhaust restriction, but it's a balance between performance and sound levels livable for a daily driver.
For $8.47 for the pair I think it's worth a shot! Shoot blew that much at taco bell today
These look similar to this http://www.carchemistry.com/cc-inserts/. Install is more involved, since they go at the front of the catback. I used these in a previous car that had headers and a a Borla. It reduced the drone around 90% with no significant power loss.
Yeah, definitely interesting... but 12 weeks!?!?!? D'oh!
https://www.youtube.com/watch?v=4mDcZGRKQ_M
-Mike
-Mike
And just to add to the thread... There is a member on here, also from Alberta, that installed cut-out valves on the lower Borla outlets.. obviously this is the best of both worlds, having the ability to tune the sound with a flick of a switch.. But for 20 min install and 20 bucks, you can't go wrong with this. In the future I'd still consider getting some cut-outs welded on
