Anyone experience this before?
Old 10-31-16, 09:33 PM
socal3
socal3's Avatar
Default Anyone experience this before?
well I just put a new battery in and I thought I solved my vsc/track and abs light issues. But now when I start my car it runs perfectly drives great but every time I get about 10 minutes/miles into my driving all the lights come on the car still runs perfectly when there on? I'll shut the car off and when I turn it on again no lights again for the same amount of time. Weird? Also don't have any check engine light so my OBD2 scanner doesn't show anything. Thanks in advance for any help I love my ISF and this forum 👍
Old 11-01-16, 04:21 AM
nks979
nks979's Avatar
No but it does sound like a battery issue, I kow others on here have reported strange things like this that were battery related.
Old 11-01-16, 05:01 AM
socal3
socal3's Avatar
I agree 100%. But I just installed a new battery 2 days ago
Old 11-01-16, 06:00 AM
nks979
nks979's Avatar
Personally I would put in another one before trying anything else, I had a battery that was brand new blow up and spray acid all over my engine bay.
Old 11-01-16, 07:06 AM
GR8WHITE
GR8WHITE's Avatar
I occasionally experience that too. I think it may be the gas cap. When it happens, after I shut the car off I re-tighten the gas cap and then I wont experience it again until next time I put gas in the car. I can't be sure until I just replace the cap altogether and it completely stops happening.
Old 11-01-16, 09:36 AM
Quadrphnia
Quadrphnia's Avatar
50% of my battery purchases end up in bad cell returns within a week. Def try another.
Old 11-01-16, 11:05 AM
PDP180180
PDP180180's Avatar
Hey,
Also worth checking your battery wires for damage.
Bad connections can cause symptoms like the ones you're describing as well.
Hope you can get it sorted soon mate.
Cheers.
Peter
Old 11-01-16, 02:22 PM
socal3
socal3's Avatar
I will try that. The battery is showing it's holdina charge and looks fine I don't know if they will let me trade it in if there is no sign of malfunction?
I'll try that any thing I'll try once at least haha. It isn't throwing a check engine light though. Wouldn't a gas cap do that?
Originally Posted by PDP180180
Hey,
Cheers.
Thanks will take a deeper look at the wires. The car had a valley plate leak I'm wondering if that could have caused a electrical problem? I need to fix this I need some headers and a tune!!!!
Peter
Old 11-01-16, 09:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,860 Likes on 2,340 Posts
Are you connecting with Techstream or a generic OBDII scanner?
Old 11-01-16, 11:22 PM
socal3
socal3's Avatar
I will be doing tech stream tomorrow I'll keep the thread updated
Old 11-02-16, 08:40 AM
916gs400
916gs400's Avatar
i had this happen to me on a different car not F and it turned out to be the alternator , might get that check out also.
Old 11-02-16, 08:12 PM
socal3
socal3's Avatar
well I hooked up the tech stream and got a few codes but then it clicked off saying ecm not responding which really worries me. I have had many cars but this problem has stumped me! Still no check engine light but every other light was on.
Old 11-02-16, 11:00 PM
socal3
socal3's Avatar
I used techstream I'm wondering if I need to clean my ecm or if I need to find a new 1 because the car wouldn't communicate with it. I know it works well cause I immediately hooked it up to my rx330 after and it worked
Old 11-02-16, 11:35 PM
2008ISF
2008ISF's Avatar
When you turn the F on, does your check engine light comeon and then go off when the engine actually starts?
Does the techstream connect to the car at all?
From the codes you posted, it looks like you need to recalibrate the yaw sensor.
If you originally used a cheapy generic scan tool to look for codes, it can trip the VSC/TRAC lights. Toyotas are weird like that.
Old 11-02-16, 11:39 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Is this an X-horse cable? The one I have won't talk to my '08 ECM, but talks fine to a '12 ECM and the wife's Scion. Not sure what the issue is, almost makes me want to get the Mongoose cable and upgrade my TIS subscription. The X-horse works fine for all the other ECUs onboard.
Quick Reply: Anyone experience this before?
