Help - Hydraulic clutch / Input Shaft quesiton
Old 08-18-16, 09:45 PM
macna
macna's Avatar
Default Help - Hydraulic clutch / Input Shaft quesiton
Hey Guys,
I don't want to jump the gun and say that I've been had, so I want to check to make sure of a few things.
The T56 style throw out bearing doesn't seem to fit over the input shaft. It's just not going to go without some abusive and possibly destructive tapping. Are people just forcing this on there?
Any options out there for a hydraulic throw out bearing that will work with the 5/8 clutch master cylinder?
In context, this is for a 1uz to W58 swap.
Old 08-18-16, 10:39 PM
salimshah
salimshah's Avatar
Received 1,019 Likes on 919 Posts
Was't there cutting of the collar in one of the conversion thread?
Shaft should pass through and the collar is trimmed back.
I would also try to position the slave with the bleeder tube pointing up to purge the air out quicker.
Salim
Old 08-20-16, 08:03 AM
macna
macna's Avatar
Salim
Got it, year had to cut the sleeve.
Old 08-22-16, 03:39 PM
YotaSC400
YotaSC400's Avatar
Do you know if a mkiii w58 will work for 1uz manual swap?
Studiogeek
01-30-16 08:58 AM
SC300_704
03-19-12 09:53 AM
93sc3005sp
17
06-05-08 03:17 PM
shonuff53
11-16-07 11:00 PM
Quick Reply: Help - Hydraulic clutch / Input Shaft quesiton
