Strut replacement question - mixing brands front and rear
Old 05-17-16, 08:03 AM
evident
evident's Avatar
Default Strut replacement question - mixing brands front and rear
I picked up a set of aftermarket KYB G2's for the rear and will be installing them later this week. Would it be OK if i installed OEM's in the front, or should I go ahead and get the aftermarket KYB's for the front as well?
Also, if I were to buy the OEM struts for the front, which parts could I reuse from my old set? would I have to buy new strut bearings, and if I do, can I mix and match the front OEM struts with aftermarket KYB parts?
Old 05-19-16, 06:43 AM
evident
evident's Avatar
I've decided that i'm going with OEM Strut mounts and bearings for the front , oem strut mounts for the rear, and sticking with all KYB G2 struts for all 4 corners....
Old 04-23-17, 06:32 AM
nikovdh
nikovdh's Avatar
Did you ever do this? I have a 99 ES300, but I'm currently deciding on what to do between OEM / KYB components.
Old 04-23-17, 06:38 AM
RedGemini
RedGemini's Avatar
Those who bought KYB for the RX usually report a stiffer ride. I'm not sure how they would be for an ES, since this is the RX section. Two completely different animals. Try asking or searching in the ES section.
Old 04-24-17, 03:12 PM
lexisaurus
lexisaurus's Avatar
I''ve just done my rears with KYBs. I was really concerned that I would loose the factory plush ride; maybe I haven't owned the RX350 for long enough to really tell but I'm really happy; I can't really tell a difference and certainly nothing jumping out as feeling not right. Fronts might be more of a noticeable change but my factory ones are just fine for now so leaving them.
Old 04-26-17, 07:13 PM
evident
evident's Avatar
Yep, car rides great. OEM Strut Mount and Strut Mount /Bearing for front works fine with the aftermarket KYB struts.
Old 05-29-17, 08:50 AM
kalcris
kalcris's Avatar
Did you use Quick struts/Strut- plus or just the strut with no springs.
Old 05-29-17, 02:17 PM
05RX330AWD
05RX330AWD's Avatar
I just replaced the rear struts with Monroe OESpectrum Struts as the front struts were fine, not sure what the ride was with OEM struts for the rear as they were totally exhausted...
although all around the ride is comfortable, most likely the way the ride should be with no bouncing & no noises at all coming from the rear of the RX.
Feels more like a newer RX ride now.
EPayne42
02-12-16 08:01 PM
99custom
Suspension and Brakes
12
09-07-14 06:25 AM
gabzor
09-06-12 06:54 PM
Leines
RX - 1st Gen (1999-2003)
06-14-12 04:45 PM
Sportznuts
17
08-23-08 01:36 PM
Quick Reply: Strut replacement question - mixing brands front and rear
