Lexus IS250 3GR-FSE Swap - Possible???
Hello everyone,
I have found that GS300 with 3GR-FSE (249hp) was with out the VDIM system!
and the same gear like in IS250!!!
so there is an option just to put 3GR-FSE engine in with his injectors ECU, and everything should work, no?
The 2GR/3GR/4GR from the late model Lexus share very similar systems (although not identical) so theoretically, bolting up should be very easy and share similar wiring. The more complicated part comes with having an ECU that can run the 3GR engine to also correspond with the current IS's technology. It would be a lot of things not working to get the engine to work properly.
I wish someone would do the swap though because its more power on a lower compression engine and japan has TONS of bolt on superchargers for the 3GR from the Mark X that comes supercharged from factory
I think the 3gr-fse engine will work using the electronics from the 4gr fse, I have done some research and found that the injectors, mass airflow, AFR sensors throttle body, fuel pump, cams and all the sensors are all the same so it should work just like factory, I confident that it will I went out and bought a 3gr-fse for myself to swap it in the is 250. Nothing try nothing done, I will put it in near the summer cause I am working 7 days a week for now
Do you have an auto or manual trunny?Do you think it can be done with manual or the ECU needs to be send to Shard to program it like Jeff did?
No ecu tunning necessary to run the 3gr-fse, the 4gr fse ecu have enough room to run the engine and mine is a manual shift car, I will post everything I have done when I do it, the extra 50hp is worth the £950 I spent for the engine, cost per hp is good
I have an '06 is250 Manual without VDIM I am thinking of using a short block (2grfse) and use my current 4grfse cylinder heads. that way I avoid the D4-S headache and use the same injectors from the old motor instead of swopping the complete motor over and sitting with the VDIM electronics and Christmas tree cluster problem
2gr swap
There are 2 differences to the 2gr block vs the 4gr, there's 2 passages between the cylinder bores that are not present in the 4gr head, not sure if it's oil passage or coolant
I can not find a way to compare the 4 heads with each other yet. In theory it should work as the compression ratios differ by 0.2 and the displacement is in the block as per the spec below the 2gr is just bigger in displacement. I have not yet had either of the heads as I have not sourced a short block or stripped mine yet still looking at if it will be feasible. although I think you wont have the full 233KW but it will be quite close. I am sure I can have the oil /coolant journals engineered in once I have the heads gas flowed. my only real concern is if the heads will bolt onto the block. the other concern is the pistons if they are flat or curved on top where the valves are I have checked the sump, timing cover, timing chains and tapped covers and camshaft housings is the same. reason why I want to do it I don't want to fiddle to much with the electronics so by keeping my heads I don't have to change ECU,s(might need to have it re-mapped) injector driver ect.. the 2gr uses the D4-S port injection the same way the 4gr uses swirl in the intake manifold so the ecu should auto ajust fuel volumes with the data it gets from the O2 sensors. it should work smoothly but it is a big step into the unknown
I already have an flywheel made since I have to do my clutch from the std but I don't want a dual mass flywheel so I opted for the solid mass flywheel with our 2005 3.0 v6 camry clutch plate and the std is250 pressure plate and bearing.
I know the gearbox ratios is close to the is350 atm(A760E) and the diff ratio on the is350 is 4.083 compared to mine 3.583(loss in top speed ) that can be sorted in aftermarket diff so the drivetrain can handle the engines output.
4grfse (cold start D4 injectors)
bore x stroke : 83.0x 77.0 mm
2grfse (cold start on port injection of D4-S)
bore x stroke : 94.0x 83.0 mm
2gr swap
I have the 4gr fse head gasket and 2gr fse, I have compared them and that the difference, except from the bigger bore of course, I live in the UK and don't have the 3.5 liter engine here so what I'm doing is the 3grfse swap which would give me 40 to 50 hp , headers exhaust and intake system will yeld another 35 hp which will result in 280 to 290 hp , the 2 engines are identical in every way except the. 5 litre capacity, same injectors throttle body oxygen sensor etc, should do the swap in a week or so
saw this on wiki...
Jeff
