CA My partout thread!!
I am also parting out my suspension setup. It is a UAS setup with Bilstein sport shocks and an Accuair E-level air management system. Fully automatic digital setup so works great. No more guessing your ride height when adjusting. Bags could use a rebuild up front. they have rub marks on them. UAS told me $45 each to rebuild them to new condition. I can do that or you can do that. So price can reflect on what needs done.
Includes:
4 Bilstein Sport shocks
4 UAS Aerosport (i rebuild them or you can)
5 Gal Air tank with 8 1/2 ports
2 Viair 480C compressors (fills up 5 gal tank in about 5 mins)
VU4 Manifold (godsend item)
E-level system (includes 4 height sensors and threaded rod)
E-level touchpad
Rocker switch system also included
2 SMC water traps (keeps water out of the tank)
2 One way valves (so you can dump air out of the tank and the bags stay inflated)
Pac 80 Amp relay (good stuff. wont fail)
will include any extra air lines i have.
Basically all you need is to bolt it up. plug and play.
$3500
PRICE DROP! 3000!
Next I have my TTE Lip. This is authentic. I've had the center indent filled because it looks cleaner to me. It's on a low car so there are scratches but that's inevitable.
$270
ebay strut tower. works good. wont fit over the GS300 engine cover. i dont know about the 400/430 engine cover
$20
I have the upgraded 01+ gauge cluster surround + clock/vent combo. This is an upgrade for the 98-00 to get the more modern look compared to the original. Looks great. No broken tabs
$110 for both
I have AF(Autofashion) rear RCA kit for the back.
$200
I have junction produce hip pads as well. These go in the gap between the seats. Definitely feels good when leaning back like a gangster. Both sides of course
$OLD
Also have my JDM aristo chrome trunk bar. No problems.
$OLD
Next I have my LS400 caliper upgrade. These have been fully polished with new OEM pads. Works great. Looks great. Rebuilt seals so you are good to go for a long time. Rotors are included as well since you can't use your stock ones. These have less than 10000 miles on them
$OLD
Also have the TRD blue sway bar combo. Includes both front and rear. These will make your car handle like a GOD.
$OLD
I also have the FIGS rear toe adjustment arms. These will allow more toe adjustments for those that are lowered. They are scratched up from all the adjustment but that's all cosmetic wise. Works like it should and that's all that matter.
$OLD
First off my Q45 retrofit. I did these myself and it came out great. I used brand new Eagle Eyes headlights and perfect Q45 projectors. Bolted on using LM brackets. These are the non-hid model so no auto leveling. These will come with the bulbs. D2S in 5000K. Here is my retrofit thread to prove. https://www.clublexus.com/forums/gs-...ofit-woes.html
$OLD + your stock
I have my grey leather and wood steering wheel combo. This is a single stage airbag so its ready to equip to your 98-00 car. Or even the 01+ if you swap your explosive unit over. The leather was dyed grey so to match the airbag. Will include the wooden shift **** as well. Matches the whole car nicely
$OLD
Some of these items will need stock parts from you. so for those ones, i am not planning to ship at all. removing the parts might also take me a few weeks. I work quite a bit so i dont have time off much. so please be patient with me
im sure many would want the front only. Shipped to ny11413. Also the figs toe if available.
