HI SAGE 18mm Front RCA kit for LS400 BBK clearance
Jan 11, 2012 | 01:14 AM
If you plan to run LS400 BBK...you will need these...its for clearance to avoid the caliper from rubbing the outer toe rod end joint....price is $145 paypal gift shipped. Comes with everything you need...the rcas, extended bolts (12.9 high grade), flat and locking washers, and cylinder rings.
Im back on coilovers so Im going back to my 40mm front RCA kit for maximum drop.
PM me if interested.
Pete
Jan 11, 2012 | 09:01 AM
i can voucher for phml even do he dont need a voucher hahahahah. got a set of rca from him A+ seller
Jan 11, 2012 | 11:23 AM
Thanks bro...
Btw...some pics of the 18mm installed on my 2GS....LS400 caliper clears the outer toe rod joint bolt...no rubbing.
Jan 13, 2012 | 01:12 AM
Jan 13, 2012 | 05:41 AM
i don't think i ever saw an answer on th18 mm version... but will these work with oem 16" wheels?
Jan 15, 2012 | 02:17 AM
Quote:
Originally Posted by
kamlung
Sure will.
pete
Jan 15, 2012 | 10:14 PM
Does it have the dowel insert?
Jan 16, 2012 | 12:06 AM
Vtur
You mean the cylinder-shaped ring? If so, YES!!!
Jan 19, 2012 | 08:01 PM
Jan 20, 2012 | 07:27 AM
Sorry for the dumb question.... with these I can run LS brakes when I go to 19s? Or are they not big enough?
Jan 20, 2012 | 02:41 PM
Are these enough to correct camber if you're slammed/ close to slammed?
Jan 20, 2012 | 06:49 PM
VIPDreamin
With these, you can run 16s, 17s, 18s, 19s, 20s...etc...no rubbing issue.
ls400love
Front RCAs don't correct camber.
Jan 21, 2012 | 06:55 PM
do those come with the extended bolts
Jan 22, 2012 | 12:48 AM
mpecilunas
Comes with everything you need...the rcas, extended bolts (12.9 high grade), flat and locking washers.
Pete
Jan 22, 2012 | 02:22 AM
Enough with the questions lol J/k. just buy the rcas guys pete wouldn't sell junk!
btw what you do with the airrunners?
