OH Biggu's 1jz/2jz/ SC 300 garage clean out *tons of pics*
Old Oct 24, 2011 | 08:03 AM
Biggu's Avatar
Biggu
Default Biggu's 1jz/2jz/ SC 300 garage clean out *tons of pics*
went through my garage this weekend and found tons of stuff id like to clear out since my car will no longer be going back to stock.
Everything is OBO since i dunno what its worth and id like to keep the big stuff local and can ship if needed.
prices do not include shipping
SC300/400 heater core / AC crap everything is there one bracket is missing but it still mounts fine. $100
2jz-GE Cams, perfect to send out to be reground $50
1jz stock cams $50
Sc300 mufflers $50
2jz-GE ECU for manual $100
2jz-ge ignitor $50
SC300 air bag sensors $25 each
Greddy Type S bypass adapter $15
Sc300 heater bypass valve $100
SC300 ABS unit and bracket $100
2jz-ge lexus timing covers $20
2jz-ge coil pack $50
2jz-ge throttle body with all sensors $75
sc300 third brake light /sub cover tan $30
1jz/2jz harmonic damper $100
SC300 front speakers and enclosure $30 each
sc300 front tweeters $15 each
Sc300 driver side speaker grill tan $5
SC300 stock pioneer Amp $30
SC300 stock pioneer capacitor $30
Old Oct 24, 2011 | 08:04 AM
Biggu's Avatar
Biggu
sc300 pioneer 12 disk in working condition $100
Sc300 Radio/ climate control setup radio works fine, climate control has some screen bleading like they all do but works fine $100 for both.
sc300 ABS wheel sensors $30 both
2jz-GE valve covers $50 for both
2jz-ge lower timing cover $20
2jz/1jz AC compressor $75 each
2jz-ge/gte? clutch fan clutch working condition $50
1jz fuel rail and injectors $50
SC300 windshield wiper sprayer res and pump $40
SC300 Clutch master, good condition the res needs a new oring $40
sc300 air bag module $20
sc300 ABS module $30
2jz/1jz lower timing cover $15
2jz-GE powersteering pump/ res/ bracket $75
2jz-ge oil filter bracket $15
1jz-gte OEM BOV $20
1jz/2jz throttle cable holder $20
Sc300 rear tan seat belt $30
1jz and a 2jz Cruise control unit with cover and cable $50 each
Soarer 1jz cross over intercooler pipe $20
Old Oct 24, 2011 | 08:06 AM
Biggu's Avatar
Biggu
SC 300 dash/ foot well ducting $15
1jz cam gears and not pictured a set of 2jz cam gears $40 for each set
sc300 tan o **** handles $10 each
1jz twin intake pipe kit plus IACV cross over pipe and custom bov block off flange $50
SC300 AC hard lines I also have the long ones and the AC condenser $75
1jz/2jz head coolant hard line $20
2jz-ge engine dip stick and tube $15
SC300 powersteering high pressure line $30
SC300 tan steering wheel and air bag $75 for both, wheel is indecent shapejust needs cleaned to get the dirt off the leather
SC300 rear speakers and mounts $30 for each
SC300 rear seat belt $30
sc300 rear tire tote $20
sc300 trunk tools/ jack tools $30
SC300/ 2jz-GE complete intake system with AFM $50(non modified for BFI)
sc300 front seat belt $30 i think its passenger side
2jz-GE sC300 throttle cable $20
SC300 sun visors one with home link retrofitted $20 for all
Biggu's Avatar
Biggu
Passenger side door skin, good shape just dirty $50
random interior pieces make an offer
sc300 radiator shroud/ducting $20
Old Oct 24, 2011 | 09:24 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100,000
I like for sale threads with good pics. how much for valve covers shipped to 80231
phamxOC's Avatar
phamxOC
can u pm me price for speaker cover and all the ac hardlines shipped to 92683
Old Oct 24, 2011 | 09:40 AM
ConSynX's Avatar
ConSynX
Doors and AC lines...are the lines bent or did the lift allow you to get em off nicely?
PS, you also have another 2jz clutch fan w/ fan.
Old Oct 24, 2011 | 09:42 AM
breed's Avatar
breed
I will pick up that Marlin Crawler shift socket from you.
Old Oct 24, 2011 | 02:28 PM
8052JZ's Avatar
8052JZ
how many miles on the power steering pump?
Old Oct 24, 2011 | 02:45 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
MY god at the parts. I will take the top 1JZ cam cover.. Will you do 30 shipped? Paypal ready.. LMK..
Old Oct 25, 2011 | 05:47 AM
Biggu's Avatar
Biggu
Cam cover and radiator are pending sale.
Old Oct 25, 2011 | 07:09 AM
ddrsquad's Avatar
ddrsquad
Pm sent for door panel
Old Oct 25, 2011 | 07:20 AM
SOARER5's Avatar
SOARER5
Is the ABS sensors same as speed sensors? I didn't know if they were one in the same or 2 separate. How much shipped to 23234?
Old Oct 25, 2011 | 08:14 AM
ddrsquad's Avatar
ddrsquad
Old Oct 25, 2011 | 08:17 PM
1J0Z SC's Avatar
1J0Z SC
Will you do $40 shipped for the clutch master cylinder?
