NE FS: Stock 2JZGTE and GE parts
Trying to get my garage cleaned out after selling my car, GE parts came off 2000 GS300 with 100k on it, GTE parts are off either my old supra (65k miles) or the JDM motor that went into the GS300 (40K miles). All prices are negotiable and shipping will be added at time of purchase. I will accept paypal only, paypal addy is supersubee@***.net . You can feel free to email me at kevinbanaszak99@gmail.com, PM me here, or call me on my cell 4029803221. Thanks.
1. Mid-Sump Oil Pickup 40$
2. Oil Filter Hanger 30$
3. Mid-Sump Lower Oil Pan 50$
4. Oil Pump 100$
5. Dipstick 10$
6. Lower Transmission Mount 50$
7. Supra Stock Intercooler Piping 50$
8. Supra Stock Motor Mounts 100$
9. Aftermarket GTE adjustable cam gears 200$
10. Stock GTE cam gears 60$
11. Lower Timing Belt Cover 15$
12. 6 Speed Supra GTE factory ECU 250$
13. Upper Cam Gear Cover 15$
14. Damaged GTE Head 200$
15. Damaged GTE Crank 100$
16. Damaged GTE Crank 100$
17. GTE Water Pump Pulley 20$
18. Rear Main Seal Cover 20$
19. Upper Transmission Mount 50$
20. Transmission Spacer 15$
21. Lower Timing Belt Pulley 30$
22. Crank Pulley Bolt 10$
23. Stock Lexus GS300 Horn 10$
24. Throttle Position Sensor 20$
25. Throttle Position Sensor 20$
26. 3 Flange Transmission Output Yoke 100$
27. GTE Timing Belt Tensioner 50$
28. GTE Coolant Neck 20$
29. Oil Pump Hanger Bolt 10$
30. Oil Pump Hanger Bolt Washer 5$
31. Oil Pump Hanger Bolt 10$
4. Oil Pump 100$
5. Dipstick 10$
and the prices.
32. Stock GTE Valve Spring 10$/Each
33. Stock GTE Valve Spring Retainer 10$/Each
34. Stock GTE Valve Spring Keeper 5$/Pair
35. Stock GTE Valve Spring Bucket 10$/Each
36. Stock GTE Intake Valve 10$/Each
37. Stock GTE Exhaust Valve 10$/Each
38. Stock GTE Valve Spring Spacer 3$/Each
39. Stock GTE Pistons & Rods 300$
40. CP Pistons with Forged Rods 600$
Ive been getting alot of emails and pms about the forged pistons and rods. The set was pulled from my built motor when it lost oil pressure. The rods are 100% fine, the pistons have some scoring on the skirts, but the machine shop i deal with has said they were reuseable. Take that as you will, every machine shop is different. So consider it a free set of pistons when you buy the rods, and you can do with them what you want. The stock set was pulled from a JDM motor when it was built, they are a little dirty, but perfect otherwise.
also, i am adding my stock 5spd trans to the list. I pulled this 5years ago, and it has been sitting in storage ever since. If you are interested, make an offer.
came out of my 2000 GS300, car had almost exactly 100k on it when i pulled it out. fluid looked great, and car ran/shifted perfectly. im not sure what its worth honestly, and shipping will probably be alot, so just a guess, but i'd say $350 shipped???
bmsport
SC400 / 300 Classifieds
Jun 22, 2010 05:12 AM
aristo007
GS - 1st Gen (1993-1997)
Apr 6, 2007 11:28 AM
DryBlaze
Nov 10, 2006 03:53 PM
