Hey guys up for sale is a set of TTC 268 cams that are BRAND NEW. They came with my motor that i bought from my good friend. Motor has been idle'd but never ran. so we can say these have 1/8 of a mile of use on them. I will have a video posted below of motor running with these cams, im not sure if you will be able to access due to being private. Here are some specs listed from TTC Performance's Website.
We're very proud of this product. TTC Performance Products has worked with a friend to help bring to the market the only viable drop in cam solution for the 2jzge motor. These cams feature the stock distributor gear, and have a profile of:
268 duration, 9.14mm lift.
Pricing is for the set:
Cores are required for these cams. Either the customer can supply cores, or TTC Performance Products can supply cores that will carry a small refundable core charge.
They are listed for 850 with stock cams as cores. or 1150 without. I am asking 700. I am firm on this price as of now. Please do not low ball me, you will be ignored. Now on to the pics and video link. Any questions. please pm me or txt me. Im located in Orlando, FL if you happen to be local.
Now I will be entertaining trades for the following items...
-R154
-Map ecu 2 OR Emanage Ultimate
-Name brand turbo ( must be decently small. this is for a drift car, ideally 57 trim)
great cams bro ,, same ones i have but bear in mind you will need to have some upgraded springs and retainers for safety as you are going to up rev limit to advantage of what they can do
cams are always designed to shift power curve to the right .. anything less then that is pointless.. and you dont want to risk valve float by moving the rpm zone to the right without supporting hardware
these cams are the **** so glws to the original poster but i do want people to know whats what
Video must be not viewable due to his privacy settings on facebook. I dont have any other videos. sorry guys. Wish i could keep them but i need to get my car running and i will make my power goals just fine with stock cams.
Well I would say about a little over 500 I had it on for a yea and drove it for about 6 months daily driven.. And then the car sat for about 4 months hasn't seen over 14psi
