IL FS: 2JZGE T70 Turbo Kit with 50mm wastegate and midpipe
I have a new T70 turbo kit for the 2JZGE for sale. I do not want to part this out and price is fairly firm. Please lets keep the thread clean and open to interested parties only.
SOLD SOLD SOLD SOLD
Kit is new and includes the following. Also you will need to delete the distributor to clear. Can use 7mgte CPS and IS300 Coils.
T70 Turbo - 70 AR Compressor - Good for 550-600 HP
Turbo Manifold
3' Down Pipe
Turbo Intake Pipe
50mm Dump Pipe
50mm Wastegate
3' Single turbo Midpipe
Oil Feed
Oil Return
V-Band Clamp
All bolts / gaskets included.
TURBO SPECS :
Maximum Horse Power 550-600 HP
Type of Cooling Oil Cooled
Inlet Size 4"
Outlet Size 2.5"
Type of Bearing WET FLOAT BEARINGS
Oil inlet Size 1/8 NTP
Maximum PSI Capacity 33 PSI
Compressor .70 AR Compressor
exducer: 72.95mm/ inducer: 57.89mm
Turbine .68 AR Turbine
Turbine wheel inducer: 83.16mm/ exducer: 54.47mm
Type of Flange T4
Type of Down Pipe Flange 3" V-band
SOLD SOLD SOLD SOLD
Turbo Manifold
3' Down Pipe
Turbo Intake Pipe
50mm Dump Pipe
50mm Wastegate
Oil Feed
Oil Return
V-Band Clamp
TURBO SPECS :
Inlet Size 4"
Outlet Size 2.5"
Type of Flange T4
scviolence
SC400 / 300 Classifieds
Dec 15, 2014 03:08 AM
Blk97SC300
28
Aug 20, 2008 09:00 PM
slwazdsm
Jun 22, 2004 07:31 PM
