Tire Pressure Transmitter ID values
1. First Ensure you have all the Five Tire Pressure Valves id numbers recorded on a paper with you. Make sure you have recorded this information prior to installation. Ensure your tires are inflated to the standard PSI.( Labelled on the Driver Door Frame or Glove Compartment).
2. Each Valve ID number are embedded with a Valve ID transmitter Number on the outer casing.
3.They are printed and be easily recogonized.
4. Now insert the DTC tool to the harness connector below the Driver Footwell where they are connected normally. And got the Diagnotics Menu and choose "Tire Pressure".
5. Now choose Utility under the sub option, and you the only option to register the Tire set.
6. Here you have two options. (a) Main Set (b) 2nd Set. Select Main Set for which you want to register the values of the tires. Once you press, a message would pop up asking do you want to ( of course ) Press Yes. And here you will 5 minutes to enter all the values.
7. Enter No of tires 5 and enter the codes below and press Enter again once you have completed. You will come up with a message, Registration Successful.
8. Now set the values of each Tire PSI values. Normal Front is 32 and Rear is also 32 and also the same for the spare tire.
9. Insert you Ignition key and only move it to the position "ON", and not start.
10. Now remove the DTC tool and reinsert again this time on the screen choose Signal check, Now it will not accept for the first time, so just move to all four wheel quickly and reduce the pressure rapidly, this theECM detect and force feeds the values of the Tire Pressure and the ID numbers instantly. That's it, Now to check if the transmitter values are registered, Inflate the tires to the OEM standard. And if the warning does not come up, that's it, good to go, Hope this helps,
Curious - How did you manage to get the Software updated, was it online, as the one I have is one version older.
thks
1. Have u rotated the tires recently.
If yes then the ID values get interchanged in the ECM,If Yes then u need to goto AutoZone and have the data entered via the scan tool. if no goto 2 Question
2. Have u replaced the tires recently.
If yes, you need to initialise the TPWS switch, which is in the Glove compartment( procedure mention in the para below) . If no goto the Third part.
3. If you have note replaced the Tire or Rotated, then the issue you have all Tires are not having exact PSI to the values as standard, a slight difference would trigger a warning from the Issue. Maintain the PSI and set it to as per the Tire Pressure Specification label on the Glove Compartment.
INITILISATION PROCESS
To initialise you need to have the tech stream tool as Tire pressure Valve IDs and the regulated Tire PSI needs to be entered . You can two set of values in the following conditions.
If the Main and 2nd Switch is in UP position The ECU will read the main set of the Tire PSI and Valve ID numbers values.( Ideal this is for regular use)
OR
If the Main and 2nd Switch is in DOWN position The ECU will read the Second set of the Tire PSI and Valve ID numbers values stored differently for any other ride condition such as Snow etc
Hope this helps
About 5 years ago, a tire store registered new sensors to the 2nd position on a customer's car, the original sensors were gone but still register as the main set. A fault for sensor signal not received/incomplete initialization (main) could not be erased. I registered the new set to both "main" and "2nd" positions. After a few minutes with the switch in the "main" position, the module completed the initialization process.
The sensor IDs can be the same for both positions (main and 2nd), just wait for the module to receive signals from all 5 sensors, there will be no faults and no warning light on.
