FL FS Brand New Custom Sub Enclosure made for 2GS
Old Sep 23, 2010 | 08:07 AM
maximus54's Avatar
maximus54
Default FS Brand New Custom Sub Enclosure made for 2GS
I had this box custom made by a professional audio shop. It fits perfectly in the recessed trunk opening in the 2GS. Box is constructed using 3/4" MDF, has two seperate sealed chambers .75 cu ft. per chamber. Box is sealed using resin as opposed to caulking for better sound quality. Each cutout is for a 10" subwoofer, but you can make it larger to fit a twelve.
This box is Brand New, I went a different route for my sound system, so I didnt use this one.
Price SOLD!!
Old Sep 23, 2010 | 10:04 AM
jtgs400's Avatar
jtgs400
So the box sits on that little shelf area right behind the rear seats right?
Old Sep 23, 2010 | 02:00 PM
toy4life86's Avatar
toy4life86
no way to fit 2 12s?
Old Sep 23, 2010 | 02:51 PM
Boostless's Avatar
Boostless
He clearly states that the holes can be opened up to fit 12's.
Old Sep 23, 2010 | 03:05 PM
maximus54's Avatar
maximus54
Yes box fits inside the little shelf. Leaving access to the spare tire. And yes you can make the holes larger to fit 12s.
Old Sep 23, 2010 | 03:54 PM
phable6's Avatar
phable6
Just because you cut the hole larger to let 12" subs fit doesn't mean the box was made for 12"s. the Cubic ft is made for 10"s so the dimensions are different.
But good luck with the SAle
Old Sep 23, 2010 | 05:51 PM
Chin's Avatar
Chin
Former Sponsor
Have you seen the enclosure? Do you know what sub is going to be placed inside the enclosure? If the seller is saying that there is physically enough space for the diameter of a 12" sub to be cut into the face and he is telling you the volume is .75 cu. ft., why are you telling everyone that his box is meant for a 10 and not a 12?
Here are the specs for a Pioneer TS-SW1201S4, please tell me why that sub wouldn't work if what the seller is saying is true...
Details:
  • 12" 4-ohm shallow-mount subwoofer
  • interlaced basalt and carbon reinforced IMPP cone
  • 3-layer urethane and fiber-woven radial surround
  • cast aluminum basket
  • Air Suspension Control System eliminates traditional spider structure
  • power range: 50-400 watts RMS (1,500 watts peak power)
  • frequency response: 20-230 Hz
  • sensitivity: 93 dB
  • mounting depth: 3-3/16"
  • sealed box volume: 0.5-1.0 cubic feet
  • ported box volume: 0.65-1.0 cubic feet
  • warranty: 3 years
Old Sep 23, 2010 | 06:56 PM
maximus54's Avatar
maximus54
Each chamber's dimensions are 12.5"x12.5"xTop Mount Depth 9.75". A 12" sub typically has an 11" cut out, so yes a twelve will work just fine.
Old Sep 24, 2010 | 09:56 AM
maximus54's Avatar
maximus54
When I had this built, I was planning on putting in 2 Alpine Type X 10" Subwoofers.
Old Sep 25, 2010 | 07:48 AM
phamxOC's Avatar
phamxOC
do u have pictures of it mounted in the trunk?
Old Sep 25, 2010 | 03:49 PM
maximus54's Avatar
maximus54
Old Sep 26, 2010 | 03:20 PM
TheBean's Avatar
TheBean
Sweet Box!!!
Old Sep 27, 2010 | 02:16 PM
maximus54's Avatar
maximus54
Originally Posted by TheBean
Sweet Box!!!
Thanks!!
Still for sale...
Old Sep 27, 2010 | 03:27 PM
Rich23's Avatar
Rich23
I wish you had one for a 15"...
Old Sep 28, 2010 | 03:58 PM
maximus54's Avatar
maximus54
When I had it built i was debating going with a single 13W7, but instead planned for 2 Type X 10's
