Suspension Springs, shocks, coilovers, sways, braces, etc.
Sage RCAs Front Drop Install
Old 08-22-10, 09:51 AM
greyhndfan
greyhndfan's Avatar
Default Sage RCAs Front Drop Install
Test fitted and isntalled RCAs in the front for a nice mild 25mm drop. So far I am loving the look and feel. This offers a pretty good alternative to get a nice drop and not have the side affects of diminished shock comfort since I am still on my stock suspension.
Here are some pics..
Removed wheel and removed the two bolts on the LBJ that holds the rotor in place.
Bolt on the two RCA blocks on the LBJ, this is where the rotor will sit.
Put Wheel back on and that's it.. Lowered look with stock suspension feel. Easy install compared to doing springs and coils..
Before and After shots..
I only dropped the front, I'm pretty happy with the rear so it may stay. The drop is mild and it does improve the look. Since it is my daily driver I didn't want to go too low. I did scrape a little when we hit some dips on the freeway, sounded like fender lining rub. I'll heat it and push back up into the tire well and see if that helps.
Old 08-22-10, 11:44 AM
JaytdotP
JaytdotP's Avatar
what kind of lip kit is that. where can i purchase it.. and how much?
Old 08-22-10, 12:51 PM
ecko1211
ecko1211's Avatar
how much and do they come in different sizes?
Old 08-22-10, 01:24 PM
redwhisky
redwhisky's Avatar
I like it....good job.
Old 08-22-10, 04:49 PM
passnu2
passnu2's Avatar
wish you were local. would like to see how the ride is.
Old 08-22-10, 04:57 PM
greyhndfan
greyhndfan's Avatar
Lip kit is Carson Tuned, it was 73.00!! Carson toyota was blowing the whole set out last year for the sides and rears all for 73.00 each. You had to buy the whole set. You'll have a hard time finding these now.
The sizes I've seen were 25mm and 30mm, they could probably build custom sizes for you..
Rides just like stock.
Old 08-22-10, 08:51 PM
3GS404
3GS404's Avatar
That's look so good bro..
Old 08-23-10, 12:40 AM
808LexGS
808LexGS's Avatar
Looks much better.
Old 08-23-10, 09:32 AM
chauss
chauss's Avatar
check the inside of your rim and make sure it is not the pitman arm rubbing!
Old 08-23-10, 11:24 AM
Kcook700
Kcook700's Avatar
Interesting. I've never seen/heard of these before. So these are a mass produced product? This would be good possibly for AWD owners like myself possibly avoiding wheel wobble? (any AWD owners have these installed?)
Old 08-23-10, 11:29 AM
GSteg
GSteg's Avatar
RCAs are somewhat mass produced. You can buy them from vendors, although the 3GS application looks very new to me.
They were designed to be used as bandaid for fixing the roll center and regaining suspension travel for cars with coilover setups. Using it on a car with shock/spring will give you the lowered effect. Depending on how low you are, adding the RCA may give you slight increase in negative camber.
Old 08-23-10, 11:45 AM
Kcook700
Kcook700's Avatar
Yeah, after checking out this post, I did a search on it. Seems like the 2GS version has been out for a few years. I assume you can use this with a stock shock and lowering spring set up.
Because my GS is AWD, I had to lower it a bit to achieve the look I wanted, thus creating negative camber. I recently swapped my F-Sport springs out for some DF-210's, which made the ride a bit more bouncy. I can probably get the same look as the DF's with these RCAs and my F-sports.
greyhndfan, what size RCAs did you use?
Old 08-23-10, 01:30 PM
designo
designo's Avatar
Interesting!
Old 08-23-10, 03:54 PM
TriniGS
TriniGS's Avatar
Never knew they made RCA's for 3Gen's. Can I use these to lower my car with my coilovers ?
Example, raise my coils then use the RCA to lower it back to the previous height. Would this work as a substitute for a front camber kit and give me positive camber ?
Eating tires a couple thousand miles is no fun but I love my drop.
Where can I purchase these RCA's ?
Ohh by the way, loving those wheels and lip kit. You get extra points for the color of your car too, lol. I'm sure others would like to see a full pic to see the drop with the front RCA and the stock rear.
Old 08-23-10, 04:32 PM
stvincent
stvincent's Avatar
this is interesting.. can anyone explain to me how this work? so this makes the car lowered yet everything else stays the same? (camber, axle, shock travel, etc..)
Quick Reply: Sage RCAs Front Drop Install
