VA Cleaning out my garage - again!! GS300+ parts
SOLD (1/11/2010)
2nd Gen Tein CS coilovers - less than 10K miles and in great shape (they do NOT need to be rebuilt)
$790 shipped
Product description
http://www.tein.com/products/comfort_sport.html
The Comfort Sport Damper has been specifically designed for drivers seeking to improve performance, without sacrificing ride quality. Vehicle sway is reduced to increase stability during cornering and increase handling. This coilover kit features a special fluorocarbon coating to protect against corrosion. The mono tube internal design with new MSV technology allows forth and quiet operation. Ride height and damping force adjustable (16-levels), as well as EDFC compatible. Developed with larger wheels and tires in mind, the spring rates and damping force provides the perfect balance of performance and comfort.
Additional Features:
• Steel Construction
• Mono Tube internal construction
• 16 way adjustable dampers, compression and rebound combined
• M.S.V. Technology for improved comfort
• Ride Height adjustable via spring seat
• Hardened Rubber upper mounts with silencer ring for increased steering feel
• Inverted design for strut type front and rear
• Teflon coated shock body
• EDFC Compatible
Less than 11K on coilover from install January 2008 through removal October 2009
$790 shipped
Product description
• EDFC Compatible
SOLD (1/11/2010)
Originally sold by Benjamin T to PHML. These have more negative camber than I can use (-2.5 to -2.8) and these are not adjustable. These are an INCREDIBLE steal at
$100 shipped
Sale did not go through on these, they are still for sale.
Here's a post from the original sale:
http://www.youzealand.net/sskit/17sskitr.html
(translated: This item is a kit which can give you 25mm stroke more because of the bolt-on. It prevent to the minimum of the vehicle hit the ground since it happen to the shortage of the shocking stroke when you lower the body
Coil suspension usually use short spring to lower the body, but after you lower the body, the shock will hit the ground, it also decreases the comfort of the driving and increase the burden to the body, and even will give too much pressure to the rims as well. So you can't have the original performance of the vehicle. But when you use this kits, you don't have to use down-suspension to lower 25mm, you can have normal stroke of shock, and it will remains the original comfort of driving.
About air suspension, you can use the controller to control the height of the body, but when you lower the body, the same problem also happen,
and because of the electrical control, the movement of the shock is getting harder, it cause the decrease of the comfort of the driving and when keep driving this conditions, it give too much pressure(stress) to the air suspension and will cause the damage. when you use this kit to lower the vehicle with air sus, since the stroke of shock can also raise the same vehicle height as former 25mm, the burden of companion a bottom of shock or air sus decreases, and a degree of comfort is also eased very much.)
https://www.clublexus.com/forums/2ge...rear-rcas.html
https://www.clublexus.com/forums/2ge...e-lowered.html
Used for less than 300 miles
$100 shipped
SOLD (1/11/2010)
Purchased for a Supercharge build but was never used or even taken out of the original packaging. This is a REAL find for those that understand HKS performance and have the need for this application.
$150 shipped
Wesite link:
http://www.hksusa.com/products/?id=3190&rsku=6260
HKS introduces the newly re-designed Super Mega Flow Reloaded intake systems. These intake systems feature HKS’ new Reloaded air filter assembly which maintains HKS’ race proven and patented Super Funnel design, but also incorporates new technical advances for improved performance and filtration.
HKS Super Mega Flow Reloaded intake systems have been granted CARB E.O. # D-186-31 for certain applications.
Also new for the Super Mega Flow Reloaded intake series is a new filter element that is constructed from three layers of different density dry polyurethane foams. This 3-layer triple density dry filter element provides improved filtration plus greater airflow compared to factory intake systems. The Super Mega Flow Reloaded intake kits offer the same simple and easy filter element replacement process as previous generations; avoiding the need to wash or re-oil the intake filter.
- New Super Honeycomb frame allows for 30% more intake surface area for improved throttle response.
- Filter assembly features a new streamline inner frame that reduces weight and allows for air to flow more smoothly into the engine.
- Plastic sealing ring at the base of the new Super Honeycomb frame helps prevent harmful containments from entering the engine and acts as a support piece for the frame.
- Aluminum back plate has been added for strength
*note most applications feature a black aluminum back plate
- 3 Layer, triple density dry filter element provides improved filtration plus greater airflow compared to factory intake systems.
Product number 70019-XT004
$150 shipped
Wesite link:
